查看: 3287|回复: 2
[分享] GeometryExtensions 源码及手册
已领礼包: 859个
发表于 2014-5-21 11:23:13 | 显示全部楼层 |阅读模式
Geometry extensions for AutoCAD .NET API.
登录/注册后可看大图
Classes
  ClassDescription
登录/注册后可看大图
CircularArc2dExtensionsProvides extension methods for the CircularArc2dType
登录/注册后可看大图
CircularArc3dExtensionsProvides extension methods for the CircularArc2dType
登录/注册后可看大图
EditorExtensionsProvides extension methods for the Editor type.
登录/注册后可看大图
EllipseExtensionsProvides extension methods for the Ellipse type.
登录/注册后可看大图
Point2dCollectionExtensionsProvides extension methods for the Point2dCollection type.
登录/注册后可看大图
Point2dExtensionsProvides extension methods for the Point2d type.
登录/注册后可看大图
Point3dCollectionExtensionsProvides extension methods for the Point3dCollection type.
登录/注册后可看大图
Point3dExtensionsProvides extension methods for the Point3d type.
登录/注册后可看大图
Polyline2dExtensionsProvides extension methods for the Polyline2d type.
登录/注册后可看大图
Polyline3dExtensionsProvides extension methods for the Polyline3d type.
登录/注册后可看大图
PolylineExtensionsProvides extension methods for the Polyline type.
登录/注册后可看大图
PolylineSegmentRepresents a Polyline segment.
登录/注册后可看大图
PolylineSegmentCollectionRepresents a PolylineSegment collection.
登录/注册后可看大图
RegionExtensionsProvides extension methods for the Region type.
登录/注册后可看大图
SplineExtensionsProvides extension methods for the Spline type.
登录/注册后可看大图
Triangle<(Of <(<'T>)>)>Provides methods for the derived classes.
登录/注册后可看大图
Triangle2dRepresents a triangle in a 2d plane. It can be viewed as a structure consisting of three Point2d.
登录/注册后可看大图
Triangle3dRepresents a triangle in the 3d space. It can be viewed as a structure consisting of three Point3d.
登录/注册后可看大图
Vector3dExtensionsProvides extension methods for the Vector3d type.
登录/注册后可看大图
ViewportExtensionsProvides extension methods for the Viewport type.
登录/注册后可看大图
Enumerations
  EnumerationDescription
登录/注册后可看大图
CoordSystemAutoCAD coordinate systems enumeration.
登录/注册后可看大图
TangentTypeTangent type enum
GeometryExtensions.zip
78.62 KB, 下载次数: 48
GeomExtDoc.zip
458.15 KB, 下载次数: 40
已领礼包: 859个
 楼主| 发表于 2014-5-21 12:58:34 来自手机 | 显示全部楼层
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
using GeometryExtensions;
using AcAp = Autodesk.AutoCAD.ApplicationServices.Application;
namespace GeometryExtensionsTestCommands
    public class MjoinCommand
        [CommandMethod("mjoin")]
        public void PolyJoin()
            Document doc = AcAp.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            TypedValue[] filter = {
                new TypedValue(-4,"<OR"),
                new TypedValue(0, "ARC,ELLIPSE,LINE,LWPOLYLINE"),
                new TypedValue(-4, "<AND"),
                new TypedValue(0, "SPLINE"),
                new TypedValue(-4, "&"),
                new TypedValue(70, 8),
                new TypedValue(-4, "AND>"),
                new TypedValue(-4, "OR>")};
            PromptSelectionResult psr = ed.GetSelection(new SelectionFilter(filter));
            if (psr.Status != PromptStatus.OK) return;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                BlockTableRecord btr =
                    (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                PolylineSegmentCollection psc = new PolylineSegmentCollection();
                Plane plane = new Plane(Point3d.Origin, Vector3d.ZAxis);
                foreach (ObjectId id in psr.Value.GetObjectIds())
                    Entity ent = (Entity)tr.GetObject(id, OpenMode.ForRead);
                    switch (ent.GetType().Name)
                        case "Arc":
                            Arc arc = (Arc)ent;
                            psc.Add(new PolylineSegment(
                                new CircularArc2d(
                                    arc.Center.Convert2d(plane),
                                    arc.Radius,
                                    arc.StartAngle,
                                    arc.EndAngle,
                                    Vector2d.XAxis,
                                    false)));
                            break;
                        case "Ellipse":
                            Ellipse el = (Ellipse)ent;
                            psc.AddRange(new PolylineSegmentCollection(el));
                            break;
                        case "Line":
                            Line l = (Line)ent;
                                new LineSegment2d(
                                    l.StartPoint.Convert2d(plane),
                                    l.EndPoint.Convert2d(plane))));
                            break;
                        case "Polyline":
                            Polyline pl = (Polyline)ent;
                            psc.AddRange(new PolylineSegmentCollection(pl));
                            break;
                        case "Spline":
                            try
                                Spline spl = (Spline)ent;
                                psc.AddRange(new PolylineSegmentCollection((Polyline)spl.ToPolyline()));
                            catch { }
                            break;
                        default:
                            break;
                foreach (PolylineSegmentCollection segs in psc.Join())
                    Polyline pline = segs.ToPolyline();
                    btr.AppendEntity(pline);
                    tr.AddNewlyCreatedDBObject(pline, true);
                tr.Commit();
已领礼包: 859个
 楼主| 发表于 2014-5-21 17:38:35 | 显示全部楼层
http://www.theswamp.org/index.php?topic=31865.30
GMT+8, 2026-11-3 10:36 , Processed in 0.467590 second(s), 36 queries , Gzip On.
