查看: 1440|回复: 2
[分享] A new C# implementation of the ConvexHull using Ling
已领礼包: 859个
发表于 2014-5-21 17:35:50 | 显示全部楼层 |阅读模式
A new C# implementation of the ConvexHull using Ling (.NET Framework 3 or upper)
  1. using System.Collections.Generic;
  2. using Autodesk.AutoCAD.ApplicationServices;
  3. using Autodesk.AutoCAD.DatabaseServices;
  4. using Autodesk.AutoCAD.EditorInput;
  5. using Autodesk.AutoCAD.Geometry;
  6. using Autodesk.AutoCAD.Runtime;
  7. using AcAp = Autodesk.AutoCAD.ApplicationServices.Application;
  8. namespace ConvexHull
  9. {
  10.     public class Commands
  11.     {
  12.         private Point2d _p0;
  13.         private bool Clockwise(Point2d p1, Point2d p2, Point2d p3)
  14.         {
  15.             return ((p2.X - p1.X) * (p3.Y - p1.Y) - (p2.Y - p1.Y) * (p3.X - p1.X)) < 1e-8;
  16.         }
  17.         private int ComparePoints(Point2d p1, Point2d p2)
  18.         {
  19.             if (p1.IsEqualTo(p2)) return 0;
  20.             double d1 = _p0.GetDistanceTo(p1);
  21.             double d2 = _p0.GetDistanceTo(p2);
  22.             if (d1 == 0.0) return -1;
  23.             if (d2 == 0.0) return 1;
  24.             double cos = (p2.X - _p0.X) / d2 - (p1.X - _p0.X) / d1;
  25.             if (cos < -1e-8) return -1;
  26.             if (cos > 1e-8) return 1;
  27.             return d1.CompareTo(d2);
  28.         }
  29.         private List<Point2d> ConvexHull(List<Point2d> pts)
  30.         {
  31.             _p0 = pts[0];
  32.             for (int i = 1; i < pts.Count; i++)
  33.             {
  34.                 Point2d pt = pts[i];
  35.                 if (pt.Y < _p0.Y || (pt.Y == _p0.Y && pt.X < _p0.X))
  36.                     _p0 = pt;
  37.             }
  38.             pts.Sort(ComparePoints);
  39.             for (int i = 1; i < pts.Count - 1; i++)
  40.             {
  41.                 while (i > 0 && Clockwise(pts[i - 1], pts[i], pts[i + 1]))
  42.                 {
  43.                     pts.RemoveAt(i);
  44.                     i--;
  45.                 }
  46.             }
  47.             return pts;
  48.         }
  49.         [CommandMethod("ch")]
  50.         public void testCh()
  51.         {
  52.             Document doc = AcAp.DocumentManager.MdiActiveDocument;
  53.             Database db = doc.Database;
  54.             Editor ed = doc.Editor;
  55.             TypedValue[] filter = new TypedValue[1] { new TypedValue(0, "POINT") };
  56.             PromptSelectionResult psr = ed.GetSelection(new SelectionFilter(filter));
  57.             if (psr.Status != PromptStatus.OK) return;
  58.             using (Transaction tr = db.TransactionManager.StartTransaction())
  59.             using (Polyline pline = new Polyline())
  60.             {
  61.                 List<Point2d> pts = new List<Point2d>();
  62.                 foreach (SelectedObject so in psr.Value)
  63.                 {
  64.                     DBPoint dbPt = (DBPoint)tr.GetObject(so.ObjectId, OpenMode.ForRead);
  65.                     pts.Add(new Point2d(dbPt.Position.X, dbPt.Position.Y));
  66.                 }
  67.                 for (int i = 0; i < ConvexHull(pts).Count; i++)
  68.                 {
  69.                     pline.AddVertexAt(i, pts[i], 0.0, 0.0, 0.0);
  70.                 }
  71.                 pline.Closed = true;
  72.                 pline.SetDatabaseDefaults();
  73.                 BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
  74.                 btr.AppendEntity(pline);
  75.                 tr.AddNewlyCreatedDBObject(pline, true);
  76.                 tr.Commit();
  77.             }
  78.         }
  79.     }
  80. }
已领礼包: 859个
 楼主| 发表于 2014-5-21 17:37:01 | 显示全部楼层
I repalced the lambda function with a delegate (ComparePoints) so that it can be used with NET Framework 2.0 (default for A2007 -> A2009)
  9. {
  11.     {
  14.         {
  16.         }
  18.         {
  28.         }
  30.         {
  31.             _p0 = pts[0];
  33.             {
  36.                     _p0 = pt;
  37.             }
  40.             {
  42.                 {
  44.                     i--;
  45.                 }
  46.             }
  47.             return pts;
  48.         }
  51.         {
  60.             {
  63.                 {
  66.                 }
  68.                 {
  70.                 }
  76.                 tr.Commit();
  77.             }
  78.         }
  79.     }
  80. }
[url]http://www.theswamp.org/index.php?topic=31865.msg373462#msg373462[/url]
已领礼包: 859个
 楼主| 发表于 2014-5-22 19:48:16 | 显示全部楼层
第一个程序测试 12W 个点时用时 32s 左右,3W个点时 3s 左右
效率有问题,还不如高飞版主的 lisp 效率高
http://bbs.xdcad.net/thread-603103-1-1.html
GMT+8, 2026-11-3 10:41 , Processed in 0.520346 second(s), 31 queries , Gzip On.
