查看: 1712|回复: 0
[分享] DCS vs. WCS (pt. 13) –Draw on DCS/PSDCS of Multiple Paper Viewports
已领礼包: 859个
发表于 2014-5-28 22:03:01 来自手机 | 显示全部楼层 |阅读模式
http://spiderinnet1.typepad.com/blog/2014/05/autocad-net-matrix-transformations-dcs-vs-wcs-pt-13-draw-on-dcspsdcs-of-multiple-paper-viewports.html
We presented various ways before to draw a rectangle with the view size regardless of Model space or Layout (Viewport or Space) in WCS or UCS, in a plan view or isometric, twisted or not. Usages of both Viewport and ViewportTableRecord were demonstrated. We also used the combination type ViewTableRecord, the handy method Editor.GetCurrentView(), and pretty the same logic and code to fulfill the same task.
A bit earlier, we created a rectangle onto the Paper Space (PSDCS) from a Viewport (Model Space) in the same Layout, with the Layout Viewport size. Previously, we transformed an entity picked in a Layout Viewport from the WCS/UCS of the Layout Viewport to the current Layout Paper Space (PSDCS or PDCS). We also transformed something on the Paper back to a picked Viewport in the same Layout.
We previously created an EntityJig, which can jig an entity such as Circle on DCS of both Layout Viewports and Paper Space.
Currently, we are going to create rectangles on DCS of both Layout Viewports regardless of count and Paper Space.
As can be seen, the command draws properly yellow rectangles on all DCSes including PSDCS of all Layout Viewports including the Paper Space itself. More than can be seen on the scene, the command works in both Layout Paper Space as shown here and Layout Viewport Model Space (please feel free activate either Viewport and try it again), and the rectangles are in the corresponding space (Model or Paper) of each Viewport always. Enjoy it!
GMT+8, 2026-11-3 11:31 , Processed in 0.500390 second(s), 31 queries , Gzip On.
