查看: 1598|回复: 1
[分享] Move Entity from Model Space to Block
已领礼包: 859个
发表于 2014-5-28 22:23:35 来自手机 | 显示全部楼层 |阅读模式
http://spiderinnet1.typepad.com/blog/2014/02/autocad-net-add-entity-in-model-space-to-block.html
In this article, let us see how to select an entity in the model space either WCS or UCS and append it to a particular block referenced by an INSERT (block reference), which is picked at the same time, maintaining the same relative position and rotation.
  1.         [CommandMethod("AddEntToBlock")]
  2.         public static void AddEntToBlock_Method()
  3.         {
  4.             Database db = HostApplicationServices.WorkingDatabase;
  5.             Editor ed = MgdAcApplication.DocumentManager.MdiActiveDocument.Editor;
  6.             try
  7.             {
  8.                 PromptEntityResult prEntRes1 = ed.GetEntity("Select an entity: ");
  9.                 PromptEntityResult prEntRes2 = ed.GetEntity("Select a block reference (INSERT) to add the entity to: ");
  10.                 if (prEntRes1.Status == PromptStatus.OK && prEntRes2.Status == PromptStatus.OK)
  11.                 {
  12.                     using (Transaction tr = db.TransactionManager.StartTransaction())
  13.                     {
  14.                         Entity ent = tr.GetObject(prEntRes1.ObjectId, OpenMode.ForWrite) as Entity;
  15.                         BlockReference insert = tr.GetObject(prEntRes2.ObjectId, OpenMode.ForRead) as BlockReference;
  16.                         if(insert == null)
  17.                         {
  18.                             ed.WriteMessage("\nThe second selected is not a block reference (INSERT).");
  19.                             return;
  20.                         }
  21.                         BlockTableRecord hostBlk = hostBlk = tr.GetObject(insert.BlockTableRecord, OpenMode.ForWrite) as BlockTableRecord;
  22.                         Matrix3d mat = insert.BlockTransform.Inverse();
  23.                         Entity clone = ent.Clone() as Entity;
  24.                         clone.TransformBy(mat);
  25.                         hostBlk.AppendEntity(clone);
  26.                         tr.AddNewlyCreatedDBObject(clone, true);
  27.                         ent.Erase();
  28.                         tr.Commit();
  29.                     }
  30.                 }
  31.             }
  32.             catch (System.Exception ex)
  33.             {
  34.                 ed.WriteMessage(ex.ToString());
  35.             }
  36.         }
If we insert a sample block into the current drawing, draw a standalone entity such as circle in red, run the command, pick the entity and the INSERT (block reference) in turn, the entity (red circle here) will be moved from the model space regardless of WCS or UCS to the block space.
  AddEntToBlock
Next time, when the same block is inserted, we will notice it has the red circle nicely added. Once again, the block can be any one defined in the current database; the block reference can have any insertion point and rotation angle; the entity and the INSERT can be in WCS or UCS; the entity can be of any type and can be anywhere as well.
Some readers may have noticed that the transformation Matrix3d does not seem to take into the current UCS, which is the case as demonstrated, in the code, but the command nicely handles both UCS and WCS. If wonder why, please keep on reading. We will reveal it soon.
已领礼包: 859个
 楼主| 发表于 2014-5-29 22:32:18 来自手机 | 显示全部楼层
仅限等比块
GMT+8, 2026-11-3 10:43 , Processed in 0.497432 second(s), 33 queries , Gzip On.
