查看: 1508|回复: 0
[分享] 让AutoCAD.NET支持后台线程
已领礼包: 859个
发表于 2014-6-1 15:52:12 | 显示全部楼层 |阅读模式
http://adndevblog.typepad.com/autocad/2012/06/use-thread-for-background-processing.html?cid=6a0167607c2431970b017742be1ec2970d Use Thread for background processingBy Adam Nagy
From inside my command I'm starting a background thread that synchronizes with a database. Once that finishes I'd like to keep using the AutoCAD .NET API to do some further modifications in the database. Unfortunately, when I'm calling the AutoCAD API functions from this thread things do not seem to work, e.g. the MdiActiveDocument is null.
Solution
The AutoCAD API's do not support multithreading. You should only call the API functions from the main thread.
If you are in a different thread then you have to marshal the call to the main thread. The simplest way to achieve that is creating a System.Windows.Forms.Control object on the main thread and call its Invoke() function to start the function that is doing the end processing.
Here is a sample to demonstrate this.
using System;
using Autodesk.AutoCAD.Runtime;
using System.Windows.Forms;
using Autodesk.AutoCAD.EditorInput;
using acApp = Autodesk.AutoCAD.ApplicationServices.Application;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
namespace BackgroundProcess
  public class Commands : IExtensionApplication
    static Control syncCtrl;
    public void Initialize()
      // The control created to help with marshaling
      // needs to be created on the main thread
      syncCtrl = new Control();
      syncCtrl.CreateControl();
    public void Terminate()
    void BackgroundProcess()
      // This is to represent the background process
      System.Threading.Thread.Sleep(5000);
      // Now we need to marshall the call to the main thread
      // I don't see how this could ever be false in this context,
      // but I check it anyway
      if (syncCtrl.InvokeRequired)
        syncCtrl.Invoke(
          new FinishedProcessingDelegate(FinishedProcessing));
      else
        FinishedProcessing();
    delegate void FinishedProcessingDelegate();
    void FinishedProcessing()
      // If we want to modify the database, then we need to lock
      // the document since we are in session/application context
      Document doc = acApp.DocumentManager.MdiActiveDocument;
      using (doc.LockDocument())
        using (Transaction tr =
          doc.Database.TransactionManager.StartTransaction())
          BlockTable bt =
            (BlockTable)tr.GetObject(
            doc.Database.BlockTableId, OpenMode.ForRead);
          BlockTableRecord ms = (BlockTableRecord)tr.GetObject(
            bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
          Line line =
            new Line(new Point3d(0, 0, 0), new Point3d(10, 10, 0));
          ms.AppendEntity(line);
          tr.AddNewlyCreatedDBObject(line, true);
          tr.Commit();
      // Also write a message to the command line
      // Note: using AutoCAD notification bubbles would be
      // a nicer solution :)
      // TrayItem/TrayItemBubbleWindow
      Editor ed = acApp.DocumentManager.MdiActiveDocument.Editor;
      ed.WriteMessage("Finished the background process!\n");
    [CommandMethod("ProcessInBackground")]
    public void ProcessBackground()
      // Let's say we got some data from the drawing and
      // now we want to process it in a background thread
      System.Threading.Thread thread =
        new System.Threading.Thread(
          new System.Threading.ThreadStart(BackgroundProcess));
      thread.Start();
      ed.WriteMessage(
        "Started background processing. " +
        "You can keep working as usual.\n");
GMT+8, 2026-11-3 10:47 , Processed in 0.493326 second(s), 28 queries , Gzip On.
