查看: 1376|回复: 0
[分享] Extend curve
已领礼包: 859个
发表于 2014-6-7 00:53:30 | 显示全部楼层 |阅读模式
        [CommandMethod("ExtendCurve", "exc", CommandFlags.Modal)]
        static public void testExtendCurve()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database db = doc.Database;
            try
                using (Transaction tr = db.TransactionManager.StartTransaction())
                    PromptEntityOptions peo = new PromptEntityOptions("\nSelect boundary edge... >>");
                    PromptEntityResult exres;
                    exres = ed.GetEntity(peo);
                    if (exres.Status != PromptStatus.OK)
                        return;
                    Entity exent = (Entity)tr.GetObject(exres.ObjectId, OpenMode.ForRead);
                    if (exent == null)
                        return;
                    Curve excur = exent as Curve;
                    peo = new PromptEntityOptions("\nSelect curve to extend >>");
                    PromptEntityResult res;
                    if (res.Status != PromptStatus.OK)
                        return;
                    Entity ent = (Entity)tr.GetObject(res.ObjectId, OpenMode.ForRead);
                    if (ent == null)
                        return;
                    if (ent.GetRXClass().DxfName == "SPLINE")
                        ed.WriteMessage("\nCould not extend the spline");
                        return;
                    Curve cur = ent as Curve;
                    Point3dCollection pts = new Point3dCollection();
                    cur.IntersectWith(excur, Intersect.ExtendThis, pts, 0, 0);
                    if (pts.Count == 0)
                       ed.WriteMessage("\nCurves aren't intersects each other");
                        return;
                    Point3d pt = pts[0];// ought be to correct this point with circle and closed polyline
                    if (!cur.IsWriteEnabled)
                        cur.UpgradeOpen();
                    Point3d pp = cur.GetClosestPointTo(res.PickedPoint, false);
                    bool sofar = false;
                    if (pp.DistanceTo(pt) < pt.DistanceTo(cur.EndPoint))
                        sofar = true;
                    if (sofar)
                        cur.Extend(true, pt);
                    else
                        cur.Extend(false, pt);
                    tr.Commit();
            catch (System.Exception ex)
                ed.WriteMessage(ex.Message );
GMT+8, 2026-11-3 12:30 , Processed in 0.551112 second(s), 28 queries , Gzip On.
