查看: 1216|回复: 0
[分享] Total length and area of curves
已领礼包: 859个
发表于 2014-6-7 00:56:33 | 显示全部楼层 |阅读模式
    [CommandMethod("tot")]
        public void testTotalLength()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            double total = 0;
            Transaction tr = doc.TransactionManager.StartOpenCloseTransaction();
            using (tr)
                TypedValue[] tv = new TypedValue[] { new TypedValue((int)DxfCode.Start, "*LINE,ARC") };
                SelectionFilter flt = new SelectionFilter(tv);
                PromptSelectionResult res = ed.GetSelection(flt);
                if (res.Status != PromptStatus.OK) return;
                SelectionSet sset = res.Value;
                if (sset.Count == 0) return;
                foreach (SelectedObject sobj in sset)
                    Entity ent = (Entity)tr.GetObject(sobj.ObjectId, OpenMode.ForRead);
                    Curve curv = ent as Curve;
                    if (curv != null)
                        total += curv.GetDistanceAtParameter(curv.EndParam);
                ed.WriteMessage("\nTotal Length:\t{0:f3}\n",total);
      [CommandMethod("toa")]
      public void testTotalArea()
          double total = 0;
          using (tr)
              // build filter to select closed curves and circles
              { new TypedValue(-4, "<or"),
                  new TypedValue(-4, "<and"),
                  new TypedValue(0, "*LINE"),
                  new TypedValue(70, 1), new TypedValue(-4, "and>"),
                  new TypedValue(0, "CIRCLE"),
                  new TypedValue(-4, "or>") };
                  if (curv != null)
                      total += curv.Area;
              ed.WriteMessage("\nTotal Area:\t{0:f3}\n", total);
GMT+8, 2026-11-3 10:45 , Processed in 0.372429 second(s), 28 queries , Gzip On.
