查看: 1515|回复: 0
[分享] Copy polyline segment
已领礼包: 859个
发表于 2014-6-7 00:57:23 | 显示全部楼层 |阅读模式
    [CommandMethod("copyseg")]
        public void copySegment()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database db = doc.Database;
            PromptEntityOptions peo = new PromptEntityOptions("\nSelect the segment to copy: ");
            peo.SetRejectMessage("\nYou have to select polyline only!");
            peo.AllowNone = false;
            peo.AllowObjectOnLockedLayer = false;
            peo.AddAllowedClass(typeof(Polyline), true);
            PromptEntityResult per = ed.GetEntity(peo);
            if (per.Status == PromptStatus.OK)
                ObjectId objId = per.ObjectId;
                try
                    using (Transaction tr = db.TransactionManager.StartTransaction())
                        Polyline pline = tr.GetObject(objId, OpenMode.ForRead, false) as Polyline;
                        if (pline != null)
                            BlockTableRecord btr = tr.GetObject(db.CurrentSpaceId,OpenMode.ForWrite, false) as BlockTableRecord;
                            Point3d pickPt = pline.GetClosestPointTo((Point3d)per.PickedPoint, false);
                            double param = pline.GetParameterAtPoint(pickPt);
                            int index = (int)param;
                          double swid=  pline.GetStartWidthAt(index);
                          double ewid = pline.GetEndWidthAt(index);
                          SegmentType stype=  pline.GetSegmentType(index);
                          if (stype == SegmentType.Line)
                             LineSegment2d lineseg= pline.GetLineSegment2dAt(index);
                              Polyline spoly = new Polyline();
                              Point2d sp = lineseg.StartPoint;
                              Point2d ep = lineseg.EndPoint;
                              spoly.AddVertexAt(0, sp, 0, swid, ewid);
                              spoly.AddVertexAt(1, ep,0,swid,ewid);
                              spoly.ColorIndex = 1;
                              btr.AppendEntity(spoly);
                              tr.AddNewlyCreatedDBObject(spoly, true);
                          if (stype == SegmentType.Arc)
                              CircularArc2d arcseg = pline.GetArcSegment2dAt(index);
                              Point2d sp = arcseg.StartPoint;
                              Point2d ep = arcseg.EndPoint;
                              double boo = pline.GetBulgeAt(index);
                              spoly.AddVertexAt(0, sp, boo, swid, ewid);
                              spoly.AddVertexAt(1, ep, boo, swid, ewid);
                              spoly.ColorIndex = 2;
                        tr.Commit();
                catch (System.Exception ex)
                    ed.WriteMessage("\nError: {0}\nTrace: {1}" , ex.Message , ex.StackTrace);
GMT+8, 2026-11-3 14:06 , Processed in 0.667156 second(s), 27 queries , Gzip On.
