查看: 1289|回复: 0
[分享] Create region from connected arcs and lines
已领礼包: 859个
发表于 2014-6-7 00:58:06 | 显示全部楼层 |阅读模式
        //Create region from connected arcs and lines
        [CommandMethod("craw")]
        public static void CreateRegionFromConnected()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database db = doc.Database;
            DBObjectCollection objs = new DBObjectCollection();
            DBObjectCollection regcoll = new DBObjectCollection();
            using (Transaction tr = db.TransactionManager.StartTransaction())
                BlockTableRecord btr = tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite) as BlockTableRecord;
                TypedValue[] tvs = new TypedValue[] { new TypedValue(0, "line,arc") };
                Point3dCollection points = new Point3dCollection();
                SelectionFilter sf = new SelectionFilter(tvs);
                PromptSelectionResult sres = ed.GetSelection(sf);
                if (sres.Status != PromptStatus.OK)
                    ed.WriteMessage("\nInvalid selection!");
                    return;
                foreach (SelectedObject selobj in sres.Value)
                    DBObject obj = tr.GetObject(selobj.ObjectId, OpenMode.ForWrite, false) as DBObject;
                    objs.Add(obj);
                regcoll = Region.CreateFromCurves(objs);
                Region reg = regcoll[0] as Region;
                btr.AppendEntity(reg);
                tr.AddNewlyCreatedDBObject(reg, true);
                // you might be want to remove the parent objects here,
                // because of DELOBJ variable did not effect :
                //foreach (DBObject obj in objs)
                //    obj.Erase();  // uncomment this code block if needs
                tr.Commit();
GMT+8, 2026-11-3 10:46 , Processed in 0.371048 second(s), 28 queries , Gzip On.
