查看: 1401|回复: 0
[分享] Create 3d polyline from points
已领礼包: 859个
发表于 2014-6-7 00:59:37 | 显示全部楼层 |阅读模式
        [CommandMethod("c3p")]
        static public void Create3dPolyline()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
         Transaction tr = db.TransactionManager.StartTransaction();
            using (tr)
                // Get blocktable and modelspace (for write)
                BlockTable bt =  (BlockTable)tr.GetObject(   db.BlockTableId, OpenMode.ForRead,  false);
                BlockTableRecord btr =(BlockTableRecord)tr.GetObject( bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite, false );
                // Create a 3D polyline with 6 segments (closed)
                Point3d[] pts = new Point3d[]
                        { new Point3d(0,0,0),
                          new Point3d(60,0,0),
                         new Point3d(60,0,60),
                         new Point3d(60,60,60),
                         new Point3d(0,60,60),
                         new Point3d(0,0,60)
                Point3dCollection points = new Point3dCollection(pts);
                Polyline3d poly = new Polyline3d();
                // First add polyline to model space and transaction
                btr.AppendEntity(poly);
                tr.AddNewlyCreatedDBObject(poly, true);
                // Then add all vertices to polyline from point collection
                foreach (Point3d pt in points)
                    // Now create the vertices
                    PolylineVertex3d vex3d = new PolylineVertex3d(pt);
                    // And add them to the 3dpoly (this adds them to the db also)
                    poly.AppendVertex(vex3d);
                    tr.AddNewlyCreatedDBObject(vex3d, true);
                // Make polyline closed
                poly.Closed = true;
                // Change color
                poly.ColorIndex = 14;
                // Commit transaction
                tr.Commit();
GMT+8, 2026-11-3 10:47 , Processed in 0.441271 second(s), 28 queries , Gzip On.
