查看: 1431|回复: 0
[分享] Write polyline points to CSV file
已领礼包: 859个
发表于 2014-6-7 01:01:13 | 显示全部楼层 |阅读模式
        [CommandMethod("PolylineToCSV", "plcsv",CommandFlags.Modal | CommandFlags.UsePickSet)]
        public static void ExportPolyPointsToCSV()
            Document doc =Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            try
                using (Transaction tr = db.TransactionManager.StartOpenCloseTransaction())
                    string dec = ((short)Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("LUPREC")).ToString();
                    PromptSelectionOptions pso = new PromptSelectionOptions();
                    pso.MessageForRemoval = "\n >>  Nothing selected....";
                    pso.MessageForAdding = "\n  >>  Select a single polyline >> ";
                    pso.AllowDuplicates = false;
                    pso.SingleOnly = true;
                    SelectionFilter sf = new SelectionFilter
                        (new TypedValue[] { new TypedValue(0, "lwpolyline") });
                    PromptSelectionResult res = ed.GetSelection(pso, sf);
                    if (res.Status != PromptStatus.OK)  return;
                    StringBuilder sb = new StringBuilder();
                    ObjectId[] ids = res.Value.GetObjectIds();
                    Polyline poly = (Polyline)tr.GetObject(ids[0], OpenMode.ForRead, false);
                    for (int i = 0; i < poly.NumberOfVertices; i++)
                        Point2d pt = poly.GetPoint2dAt(i);
                        string vexstr = string.Format("{0:f" + dec + "};{1:f" + dec + "}", pt.X, pt.Y);
                        sb.AppendLine(vexstr);
                    String csvFile = String.Empty;
                    System.Windows.Forms.SaveFileDialog sfd =  new System.Windows.Forms.SaveFileDialog();
                    sfd.ValidateNames = true;
                    sfd.Title = "Save polyline vertices to CSV file";
                    sfd.DefaultExt = ".csv";
                    sfd.InitialDirectory=@"C:\Test\";
                    sfd.RestoreDirectory = true;
                    if (sfd.ShowDialog() != System.Windows.Forms.DialogResult.OK)  return;
                    csvFile = sfd.FileName;
                    // write point to defined file
                    using (StreamWriter sw = new StreamWriter(csvFile))
                        sw.Write(sb.ToString());
                        sw.Flush();
                    sfd.Dispose();// non resident object, so kill 'em
                    tr.Commit();
            catch (Autodesk.AutoCAD.Runtime.Exception ex)
                ed.WriteMessage("\n" + ex.Message + "\n" + ex.Source + "\n" + ex.StackTrace);
GMT+8, 2026-11-3 11:39 , Processed in 0.409995 second(s), 27 queries , Gzip On.
