查看: 1294|回复: 0
[分享] Add bulged segment (create jumpover)
已领礼包: 859个
发表于 2014-6-7 01:08:23 | 显示全部楼层 |阅读模式
       public static void Jumper()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Matrix3d ucs = ed.CurrentUserCoordinateSystem;
            Database db = doc.Database;
            PromptEntityResult res = ed.GetEntity(new PromptEntityOptions("Select polyline : "));
            if (res.Status != PromptStatus.OK) return;
            ObjectId id = res.ObjectId;
            Point3d pp = res.PickedPoint;
            // Set break gap
            double gap = 3.0;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                BlockTable bt = (BlockTable)db.BlockTableId.GetObject(OpenMode.ForRead);
                BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                Entity ent = tr.GetObject(id, OpenMode.ForWrite) as Entity;
                Polyline poly = ent as Polyline;
                if (poly == null) return;
                pp = poly.GetClosestPointTo(pp, false).TransformBy(ucs);
                double par = poly.GetParameterAtPoint(pp);
                double dist = poly.GetDistAtPoint(pp);
                int idx = (int)par;
                Point3d p1 = poly.GetPointAtDist(dist - gap/2).TransformBy(ucs);
                Point3d p2 = poly.GetPointAtDist(dist + gap/2).TransformBy(ucs);
                poly.AddVertexAt(idx+1, new Point2d(p1.X, p1.Y), 1, 0, 0);
                poly.AddVertexAt(idx+2, new Point2d(p2.X, p2.Y), 0, 0, 0);
                tr.Commit();
GMT+8, 2026-11-3 10:44 , Processed in 0.377847 second(s), 28 queries , Gzip On.
