查看: 1620|回复: 0
[分享] Breaking a curve at a point
已领礼包: 859个
发表于 2014-6-7 01:11:07 | 显示全部楼层 |阅读模式
//        based on code by Balaji Ramamoorthy
//        http://adndevblog.typepad.com/au ... rve-at-a-point.html
       [CommandMethod("bre")]
        public static void ADSProjectBreak()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Matrix3d ucs = ed.CurrentUserCoordinateSystem;
            Database db = HostApplicationServices.WorkingDatabase;
            ObjectId id;
            Entity ent;
            try
                using (Transaction tr = db.TransactionManager.StartTransaction())
                    BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                    // Let the user select a curve
                    id = ed.GetEntity("\nSelect curve: ").ObjectId;
                    if (id == ObjectId.Null) return;
                    ent = (Entity)tr.GetObject(id, OpenMode.ForRead, false);
                    if (ent == null) return;
                    // Check that it is really a curve
                    Curve Curve = ent as Curve;
                    if (Curve == null) return;
                    // Get the break position and convert to WC coordinates
                    Point3d breakPnt;
                    breakPnt = ed.GetPoint("\nPick a point on the curve: ").Value;
                    breakPnt.TransformBy(ucs.Inverse());
                    // Check that the point is on the curve
                    breakPnt = Curve.GetClosestPointTo(breakPnt, false);
                    Point3dCollection breakPoints = new Point3dCollection();
                    DBObjectCollection newCurves = new DBObjectCollection();
                    // Get the segments according to the trim points
                    breakPoints.Add(breakPnt);
                    newCurves = Curve.GetSplitCurves(breakPoints);
                    if (newCurves == null)
                        ed.WriteMessage("\nGetSplitCurves failed :  Error");
                        return;
                    // Here we add the segments to the database with different colors
                    for (int i = 0; i < newCurves.Count; i++)
                        Entity pent = (Entity)newCurves as Entity;
                        pent.SetPropertiesFrom(ent);
                        pent.ColorIndex = i + 1;// to display result only
                        btr.AppendEntity(pent);
                        tr.AddNewlyCreatedDBObject(pent, true);
                        tr.TransactionManager.QueueForGraphicsFlush();
                    ent.UpgradeOpen();
                    ent.Erase();
                    doc.TransactionManager.FlushGraphics();
                    tr.Commit();
            catch (Autodesk.AutoCAD.Runtime.Exception ex)
                Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog(ex.Message + "\n" + ex.StackTrace);
            finally
                ed.WriteMessage("\nPokey");
GMT+8, 2026-11-3 11:31 , Processed in 0.371097 second(s), 28 queries , Gzip On.
