查看: 1861|回复: 0
[分享] Intersect line with curve
已领礼包: 859个
发表于 2014-6-7 01:12:08 | 显示全部楼层 |阅读模式
        [CommandMethod("IntLineCurve","ilw", CommandFlags.Modal | CommandFlags.UsePickSet | CommandFlags.Redraw )]
        public void IntersectTestIn()
            Database db = HostApplicationServices.WorkingDatabase;
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                PromptEntityOptions peo = new PromptEntityOptions("\nSelect a Line >>");
                peo.SetRejectMessage("\nYou have to select the Line only >>");
                peo.AddAllowedClass(typeof(Line), false);
                PromptEntityResult res;
                res = ed.GetEntity(peo);
                if (res.Status != PromptStatus.OK)
                    return;
                Entity ent = (Entity)tr.GetObject(res.ObjectId, OpenMode.ForRead);
                if (ent == null)
                    return;
                Line line = (Line)ent as Line;
                if (line == null) return;
                peo = new PromptEntityOptions("\nSelect a curve: ");
                peo.SetRejectMessage("\nYou have to select the curve only >>");
                peo.AddAllowedClass(typeof(Curve), false);
                    return;
                if (ent == null)
                    return;
                Curve pline = (Curve)ent as Curve;
                if (pline == null) return;
                Point3dCollection pts = new Point3dCollection();
                line.IntersectWith(pline, Intersect.OnBothOperands, pts, 0, 0);//<-- A2010
                if (pts.Count == 0) return;
                List<Point3d> points = new List<Point3d>();
                foreach (Point3d p in pts)
                    points.Add(p);
                Point3d sp = line.StartPoint;
                points.Sort(delegate(Point3d p1, Point3d p2)
                    return Convert.ToInt32(
                            Convert.ToDouble(sp.DistanceTo(p1).CompareTo(
               Convert.ToDouble(sp.DistanceTo(p2)))));
                pts = new Point3dCollection(points.ToArray());
                DBObjectCollection objs = line.GetSplitCurves(pts);
                List<DBObject> lstobj = new List<DBObject>();
                foreach (DBObject dbo in objs)
                    lstobj.Add(dbo);
                BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                int i=1;
                    Line ln = dbo as Line;
                    if (!ln.IsWriteEnabled)
                        ln.UpgradeOpen();
                    ln.SetPropertiesFrom(line);
                    ln.ColorIndex=i;
                    btr.AppendEntity(ln);
                    tr.AddNewlyCreatedDBObject(ln, true);
                    if (i > 255)
                        i = 1;
                    else
                        i += 1;
                if (!line.IsWriteEnabled)
                    line.UpgradeOpen();
                line.Erase();
                line.Dispose();
                ed.Regen();
                tr.Commit();
GMT+8, 2026-11-3 10:41 , Processed in 0.177644 second(s), 28 queries , Gzip On.
