查看: 1280|回复: 0
[分享] Getting the Midpoint of each Polyline Segment
已领礼包: 859个
发表于 2014-6-7 01:13:43 | 显示全部楼层 |阅读模式
      [CommandMethod("smp")]
        public void ShowMidPointOnEachSegment()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database db = HostApplicationServices.WorkingDatabase;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                BlockTableRecord btr = tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite) as BlockTableRecord;
                Entity ename;
                PromptEntityOptions peo = new PromptEntityOptions("\nSelect Polyline: ");
                peo.SetRejectMessage("\nMust be a Polyline.");
                peo.AddAllowedClass(typeof(Polyline), false);
                PromptEntityResult retval = ed.GetEntity(peo);
                if (retval.Status != PromptStatus.OK)   return;
                Curve curv;
                ObjectId id;
                id = retval.ObjectId;
                ename = tr.GetObject(id, OpenMode.ForWrite) as Entity;
                curv = ename as Curve;
                if (curv == null)
                    ed.WriteMessage("\nCould not cast object as Curve.");
                    return;
                if (!curv.IsWriteEnabled)
                    curv.UpgradeOpen();
                double startParam, endParam;
                // get the start param, usually it starts at 0 or 1
                startParam = curv.StartParam;
                ed.WriteMessage("\nStartParam is: {0:f3}\n", startParam);
                // get the end param, for a polyline it's the total number of
                // vertex's -1
                endParam = curv.EndParam;
                ed.WriteMessage("\nEndParam is: {0:f3}\n", endParam);
                // now loop the parameters, adding 1.0 each iteration
                for (double i = startParam; i < endParam; ++i)
                    Point3d pt;
                    pt = curv.GetPointAtParameter(i + 0.5);
                  //  DBPoint dp = new DBPoint(pt);
                    Circle cr = new Circle(pt, Vector3d.ZAxis, 2.5);
                    btr.AppendEntity(cr);
                    tr.AddNewlyCreatedDBObject(cr, true);
                    ed.WriteMessage("\nPoint: {0}, {1}, {2}\n", pt[0], pt[1], pt[2]);
                tr.Commit();
GMT+8, 2026-11-3 10:40 , Processed in 0.435584 second(s), 28 queries , Gzip On.
