查看: 1253|回复: 0
[分享] Draw grid by picking corners
已领礼包: 859个
发表于 2014-6-7 01:14:22 | 显示全部楼层 |阅读模式
        public static void TestGraph()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Matrix3d ucs = ed.CurrentUserCoordinateSystem;
            PromptPointOptions ppo = new PromptPointOptions("\nJust a Lower Left corner: ");
            PromptPointResult ppr = ed.GetPoint(ppo);
            if (ppr.Status != PromptStatus.OK)
                return;
            PromptCornerOptions pco = new PromptCornerOptions("\nUpper Right corner: ", ppr.Value);
            PromptPointResult pcr = ed.GetCorner(pco);
            if (pcr.Status != PromptStatus.OK)
                return;
            Point3d p1 = ppr.Value;
            Point3d p2 = pcr.Value;
            if (((p1.X == p2.X || p1.Y == p2.Y) & (p2.X > p1.X || p2.Y > p1.Y)))
                ed.WriteMessage("\nWrong coordinate specification");
                return;
            // Calculate the four corner points of the box
            // and add them to a Point3dCollection:
            Point3dCollection points = new Point3dCollection();
            points.Add(p1);
            points.Add(new Point3d(p2.X, p1.Y, 0.0));
            points.Add(p2);
            points.Add(new Point3d(p1.X, p2.Y, 0.0));
            double leng = 0;
            leng = p2.X - p1.X;
            double wid = 0;
            wid = p2.Y - p1.Y;
            PromptIntegerOptions pio = new PromptIntegerOptions("");
            pio.Message = "\nEnter the number of rows: ";
            // Restrict input to positive and non-negative values
            pio.AllowZero = false;
            pio.AllowNegative = false;
            // Add default value
            pio.DefaultValue = 4;
            pio.AllowNone = true;
            // Get the value entered by the user
            PromptIntegerResult ires = ed.GetInteger(pio);
            if (ires.Status != PromptStatus.OK)
                return;
            int rownum = ires.Value;
            pio.Message = "\nnEnter the number of columns: ";
            pio.DefaultValue = 8;
            PromptIntegerResult ires2 = ed.GetInteger(pio);
            if (ires2.Status != PromptStatus.OK)
                return;
            int colnum = ires2.Value;
            double rowstep = 0;
            rowstep = wid / rownum;
            double colstep = 0;
            colstep = leng / colnum;
            Database db = ed.Document.Database;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                BlockTableRecord btr = tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite) as BlockTableRecord;
                Plane plan = new Plane(Point3d.Origin, Vector3d.ZAxis);
                Polyline poly = new Polyline(4);
                int i = 0;
                foreach (Point3d pt in points)
                    poly.AddVertexAt(i, pt.Convert2d(plan), 0, 0, 0);
                    i += 1;
                poly.Closed = true;
                btr.AppendEntity(poly);
                tr.AddNewlyCreatedDBObject(poly, true);
                Point3dCollection vps = new Point3dCollection();
                Point3dCollection hps = new Point3dCollection();
                for (i = 1; i <= rownum - 1; i++)
                    vps.Add(new Point3d(p1.X, p1.Y + (i * rowstep), p1.Z));
                for (i = 1; i <= colnum - 1; i++)
                    hps.Add(new Point3d(p1.X + (i * colstep), p1.Y, p1.Z));
                Line ln = new Line();
                foreach (Point3d pt in vps)
                    ln = new Line(pt, new Point3d(pt.X + leng, pt.Y, 0));
                    btr.AppendEntity(ln);
                    tr.AddNewlyCreatedDBObject(ln, true);
                foreach (Point3d pt in hps)
                    ln = new Line(pt, new Point3d(pt.X, pt.Y + wid, 0));
                tr.Commit();
GMT+8, 2026-11-3 11:30 , Processed in 0.442591 second(s), 28 queries , Gzip On.
