查看: 1453|回复: 0
[分享] Creating 3D Solids programmatically
已领礼包: 859个
发表于 2014-6-7 01:16:41 | 显示全部楼层 |阅读模式
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
namespace ExtrudedSolidSample
    public class Commands
        [CommandMethod("Test")]
        public void Test()
            Database db = HostApplicationServices.WorkingDatabase;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                // Create a closed polyline (it have to be disposed because it won't be added to the database)
                using (Polyline pline = new Polyline(12))
                    pline.AddVertexAt(0, new Point2d(100.0, 100.0), 0.0, 0.0, 0.0);
                    pline.AddVertexAt(0, new Point2d(200.0, 100.0), 0.0, 0.0, 0.0);
                    pline.AddVertexAt(0, new Point2d(200.0, 130.0), 0.0, 0.0, 0.0);
                    pline.AddVertexAt(0, new Point2d(180.0, 130.0), 0.0, 0.0, 0.0);
                    pline.AddVertexAt(0, new Point2d(180.0, 170.0), 0.0, 0.0, 0.0);
                    pline.AddVertexAt(0, new Point2d(200.0, 170.0), 0.0, 0.0, 0.0);
                    pline.AddVertexAt(0, new Point2d(200.0, 200.0), 0.0, 0.0, 0.0);
                    pline.AddVertexAt(0, new Point2d(100.0, 200.0), 0.0, 0.0, 0.0);
                    pline.AddVertexAt(0, new Point2d(100.0, 170.0), 0.0, 0.0, 0.0);
                    pline.AddVertexAt(0, new Point2d(120.0, 170.0), 0.0, 0.0, 0.0);
                    pline.AddVertexAt(0, new Point2d(120.0, 130.0), 0.0, 0.0, 0.0);
                    pline.AddVertexAt(0, new Point2d(100.0, 130.0), 0.0, 0.0, 0.0);
                    pline.Closed = true;
                    DBObjectCollection curves = new DBObjectCollection { pline };
                    // Create a region (it have to be disposed because it won't be added to the database)
                    using(DBObjectCollection regions = Region.CreateFromCurves(curves))
                        // Create a solid 3d (it will be added to the database)
                        Solid3d solid = new Solid3d();
                        solid.Extrude((Region)regions[0], 500.0, 0.0);
                        BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
                        BlockTableRecord btr =
                            (BlockTableRecord)tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
                        btr.AppendEntity(solid);
                        tr.AddNewlyCreatedDBObject(solid, true);
                        // Create a slicing plane
                        Plane plane = new Plane(new Point3d(200.0, 200.0, 500.0), new Vector3d(0.0, 1.0, -1.0));
                        // Slice the solid 3d with the plane
                        solid.Slice(plane, true);
                tr.Commit();
GMT+8, 2026-11-3 10:40 , Processed in 0.470774 second(s), 28 queries , Gzip On.
