查看: 1445|回复: 0
[分享] Ellipsoid Solid
已领礼包: 859个
发表于 2014-6-7 01:17:52 | 显示全部楼层 |阅读模式
using System;
using System.IO;
using System.Collections.Generic;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Windows;
[CommandMethod("Ellipsoid")]
        //Basic method to put an ellipsoid at WCS origin
        static public void OpInitEl()
            Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
            PromptDoubleOptions pdo = new PromptDoubleOptions("\nEnter Length ");
            pdo.AllowArbitraryInput = true;
            pdo.AllowNegative = false;
            PromptDoubleResult pdr = ed.GetDouble(pdo);
            if (pdr.Status != PromptStatus.OK || pdr.Value <= 0) return;
            double Length = pdr.Value;
            pdo.Message = " Enter Width";
            double Width = pdr.Value;
            pdo.Message = " Enter Height";
            double Height = pdr.Value;
            Double[] matarr = new Double[16]{Length/2, 0.0,0.0,0.0,
                                                0.0,Width/2,0.0,0.0,
                                                0.0,0.0,Height/2,0.0,
                                                0.0,0.0,0.0,1.0};
            Matrix3d mat = new Matrix3d(matarr);
            Point3dCollection Cvs = GenCVs();
            //Scale points from sphere to ellipsoid
            for (int i = 0; i < 9; i++ )
                Cvs[i] = Cvs[i].TransformBy(mat);
            DoubleCollection Dc = GenWghts();
            KnotCollection[] Knots = GenKnots();
            Database db = HostApplicationServices.WorkingDatabase;
            using (Transaction trans = db.TransactionManager.StartTransaction())
                BlockTableRecord btr = (BlockTableRecord)(trans.GetObject(db.CurrentSpaceId, OpenMode.ForWrite));
                try
                    //Generate the ellipsoid Octant
                    Autodesk.AutoCAD.DatabaseServices.NurbSurface NS = new Autodesk.AutoCAD.DatabaseServices.NurbSurface
                        (2, 2, true, 3, 3, Cvs, Dc,
                        Knots[0], Knots[1]);
                    //Create, mirror and union
                    Solid3d sol = new Solid3d();
                    sol.CreateBox(Length, Width, Height);
                    sol.TransformBy(Matrix3d.Scaling(0.5, new Point3d(Length / 2.0, Width / 2.0, Height / 2.0)));
                    sol.Slice(NS);
                    NS.Dispose();//Perhaps not specifically necessary - as NS is transaction resident
                    Plane Mir = new Plane(new Point3d(), new Vector3d(1.0,0.0,0.0));
                    Solid3d solMirr = sol.GetTransformedCopy(Matrix3d.Mirroring(Mir)) as Solid3d;
                    sol.BooleanOperation(BooleanOperationType.BoolUnite, solMirr);
                    Mir = new Plane(new Point3d(), new Vector3d(0.0, 1.0, 0.0));
                    Mir = new Plane(new Point3d(), new Vector3d(0.0, 0.0, 1.0));
                    sol.SetDatabaseDefaults();
                    btr.AppendEntity(sol);
                    trans.AddNewlyCreatedDBObject(sol, true);
                    trans.Commit();
                catch
                    trans.Abort();
        private static Point3dCollection GenCVs()
            //Generate Control Vertices for one octant of nurb based sphere
            Point3dCollection tempPts = new Point3dCollection();
            tempPts.Add(new Point3d(1.0, 0.0, 0.0));
            tempPts.Add(new Point3d(1.0, 0.0, 1.0));
            tempPts.Add(new Point3d(0.0, 0.0, 1.0));
            tempPts.Add(new Point3d(1.0, 1.0, 0.0));
            tempPts.Add(new Point3d(1.0, 1.0, 1.0));
            tempPts.Add(new Point3d(0.0, 1.0, 0.0));
            tempPts.Add(new Point3d(0.0, 1.0, 1.0));
            return tempPts;
        private static DoubleCollection GenWghts()
            //Generate weights for rational nurb surface
            DoubleCollection temp = new DoubleCollection(9);
            Double NearCorner = Math.Sqrt(0.5);
            temp.Add(1.0);
            temp.Add(NearCorner);
            temp.Add(1.0);
            temp.Add(0.5);
            temp.Add(1.0);
            temp.Add(1.0);
            return temp;
        private static KnotCollection[] GenKnots()
            //Generate knot vectors for PI based paramatization - uniform span from 0 to Pi/2 in U
            //                                                  - uniform span from 0 to Pi/2 in V
            KnotCollection[] tempKnots = new KnotCollection[2];
            tempKnots[0] = new KnotCollection();
            tempKnots[0].Add(0.0);
            tempKnots[0].Add(Math.PI / 2);
            tempKnots[1] = new KnotCollection();
            tempKnots[1].Add(0.0);
            tempKnots[1].Add(Math.PI / 2);
            return tempKnots;
GMT+8, 2026-11-3 12:30 , Processed in 0.460009 second(s), 28 queries , Gzip On.
