查看: 2196|回复: 1
[分享] Create 3D solid by extruding a polyline
已领礼包: 859个
发表于 2014-6-7 01:18:47 | 显示全部楼层 |阅读模式
     // based on C++ code by Virupaksha Aithal from this page:
      //http://adndevblog.typepad.com/autocad/2012/08/create-3d-solid-by-extruding-a-polyline.html
       [CommandMethod("extt")]
        public void CreateExtrude()
            Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("delobj", 1);
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            PromptSelectionOptions pso = new PromptSelectionOptions();
            pso.SingleOnly = true;
            pso.SinglePickInSpace = true;
            pso.MessageForAdding = "\nPlease select a polyline: ";
            pso.MessageForRemoval = "Failed to select a polyline";
            pso.PrepareOptionalDetails = true;
            SelectionFilter filter =
                new SelectionFilter(
                new TypedValue[] { new TypedValue(0, "lwpolyline"),new TypedValue(70, 1) });
            //select the polyline
            PromptSelectionResult sres = ed.GetSelection(pso,filter);
            if (sres.Status != PromptStatus.OK) return;
            using (Transaction tr = doc.TransactionManager.StartTransaction())
                //get the boundary curves of the polyline
                ObjectId idPoly = sres.Value[0].ObjectId;
                Entity pEntity = tr.GetObject(idPoly, OpenMode.ForRead) as Entity;
                Polyline pPoly = pEntity as Polyline; ;
                if (pPoly == null) return;
                DBObjectCollection lines = new DBObjectCollection();
                pPoly.Explode(lines);
                // Create a region from the set of lines.
                DBObjectCollection regions = new DBObjectCollection();
                regions = Region.CreateFromCurves(lines);
                if (regions.Count == 0)
                    ed.WriteMessage("\nFailed to create region\n");
                    return;
                Region pRegion = (Region)regions[0];
                // Extrude the region to create a solid.
                Solid3d pSolid = new Solid3d();
                pSolid.RecordHistory = true;
                pSolid.Extrude(pRegion, 10.0, 0.0);
                ObjectId savedExtrusionId = ObjectId.Null;
                ObjectId modelId;
                modelId = SymbolUtilityServices.GetBlockModelSpaceId(db);
                BlockTableRecord btr = tr.GetObject(modelId, OpenMode.ForWrite) as BlockTableRecord;
                savedExtrusionId = btr.AppendEntity(pSolid);
                tr.AddNewlyCreatedDBObject(pSolid,true);
                if (!pPoly.IsWriteEnabled) pPoly.UpgradeOpen();
                pPoly.Erase();
                tr.Commit();
发表于 2020-8-13 10:47:05 | 显示全部楼层
你好,想请教一下关于扫掠的问题?我写好代码,选择CAD图中的截面和路径,就是扫掠不出来。
GMT+8, 2026-11-3 11:11 , Processed in 0.471926 second(s), 30 queries , Gzip On.
