查看: 1557|回复: 0
[分享] Count blocks by attribute value
已领礼包: 859个
发表于 2014-6-7 01:20:19 | 显示全部楼层 |阅读模式
        // using System.Linq;
        #region "Selection block by attribute tag"
        //      get the real block name.        //
        public static string EffectiveName(Transaction tr, BlockReference bref)
            BlockTableRecord btr = null;
            if ((bref.IsDynamicBlock)
                | (bref.Name.StartsWith("*U", StringComparison.InvariantCultureIgnoreCase)))
                btr = tr.GetObject(bref.DynamicBlockTableRecord, OpenMode.ForRead) as BlockTableRecord;
            else
                btr = tr.GetObject(bref.BlockTableRecord, OpenMode.ForRead) as BlockTableRecord;
            return btr.Name;
        [CommandMethod("SelectByAttributeValue", "byval", CommandFlags.Modal)]
        public void GetSelectionByAtt()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            string m_str = string.Empty;
            PromptStringOptions psto = new PromptStringOptions("\nEnter the tag to find (case-nonsensitive): ");
            // to disable the blank space in user input
            psto.AllowSpaces = false;
            PromptResult pstr = ed.GetString(psto);
            if (pstr.Status != PromptStatus.OK) return;
            m_str = pstr.StringResult.ToUpper();
            List<object[]> blockdata = new List<object[]>();
            PromptSelectionOptions pso = new PromptSelectionOptions();
            pso.MessageForRemoval = "\nFailed to select a blocks!";
            pso.MessageForAdding = "\nPlease select a blocks: ";
            // build filter to select all attributed blocks
            SelectionFilter filter =
                new SelectionFilter(
                new TypedValue[] { new TypedValue(0, "insert"),
                    new TypedValue(66, 1) }
            // perform block selection
            PromptSelectionResult sres = ed.GetSelection(pso, filter);// might be SelectAll instead
            if (sres.Status != PromptStatus.OK) return;
            try
                SelectionSet sset = sres.Value;
                using (Transaction tr = db.TransactionManager.StartTransaction())
                    foreach (SelectedObject sobj in sset)
                        Entity ent = tr.GetObject(sobj.ObjectId, OpenMode.ForRead, false) as Entity;
                        BlockReference bref = ent as BlockReference;
                        AttributeCollection attribs = bref.AttributeCollection;
                        foreach (ObjectId attid in attribs)
                            AttributeReference attref = tr.GetObject(attid, OpenMode.ForRead, false) as AttributeReference;
                            if (attref.Tag == m_str)
                                object[] datum = new object[] { EffectiveName(tr, bref), attref.Tag, attref.TextString };
                                // add block  info to the list
                                blockdata.Add(datum);
                    // display total result
                    //foreach (object[] item in blockdata)
                    //    ed.WriteMessage("\n{0}\t{1}\t{2}", item[0], item[1],item[2]);
                    var grps = from blk in blockdata
    group blk by new
        Name =blk.ElementAt(0), Tag =blk.ElementAt(1),AttValue=blk.ElementAt(2)
    into grp
    select new
        BlockName=grp.First().ElementAt(0),
        Tag=grp.First().ElementAt(1),
        AttValue=grp.First().ElementAt(2),
        Count= grp.Count()
                    // display subtotals
                    foreach (var grp in grps)
                        ed.WriteMessage("\n[ Block Name: {0} |Tag: {1} | Value: {2} | Count: {3} ]\n",
                            grp.BlockName,
                            grp.Tag,
                            grp.AttValue,
                            grp.Count
                    tr.Commit();
            catch (System.Exception ex)
                Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog(ex.Message + "\n" + ex.StackTrace);
            finally
        #endregion
GMT+8, 2026-11-3 10:17 , Processed in 0.375795 second(s), 28 queries , Gzip On.
