查看: 1919|回复: 1
[分享] Create block with attributes (2009)
已领礼包: 859个
发表于 2014-6-7 01:21:50 | 显示全部楼层 |阅读模式
         [CommandMethod("STATION")]
        public static void CreateStation()
            // Get the current document and database
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            // Start a transaction
            using (Transaction tr = db.TransactionManager.StartTransaction())
                try
                    BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForWrite);
                    string blkName = "STATION";
                    if (bt.Has(blkName))
                        ed.WriteMessage("\nBlock \"STATION\" already exist.");
                        return;
                    BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                    Point3d inspt = new Point3d(0, 0, 0);
                    BlockTableRecord newBtr = new BlockTableRecord();
                    bt.Add(newBtr);
                    newBtr.Name = blkName;
                    newBtr.Origin = inspt;
                    newBtr.BlockScaling = BlockScaling.Uniform;
                    newBtr.Units = UnitsValue.Inches;
                    newBtr.Explodable = true;
                    tr.AddNewlyCreatedDBObject(newBtr, true);
                    Line ln = new Line();
                    ln.StartPoint = new Point3d(0.5, 0, 0);
                    ln.EndPoint = new Point3d(12, 0, 0);
                    Circle circ = new Circle();
                    circ.Center = inspt;
                    circ.Radius = 0.5;
                    AttributeDefinition attr = new AttributeDefinition();
                    attr.Tag = "NUMBER";
                    attr.Prompt = "Station number:";
                    attr.TextString = "1";
                    attr.Verifiable = true;
                    attr.LockPositionInBlock = true;
                    //attr.TextStyle = db.Textstyle;//<--   A2009
                    attr.TextStyleId = db.Textstyle;//<--   A2010
                    attr.Height = 1.0;
                    attr.Position = new Point3d(6.0, 0.5, 0);
                    attr.AdjustAlignment(db);
                    newBtr.AppendEntity(ln);
                    tr.AddNewlyCreatedDBObject(ln, true);
                    newBtr.AppendEntity(circ);
                    tr.AddNewlyCreatedDBObject(circ, true);
                    newBtr.AppendEntity(attr);
                    tr.AddNewlyCreatedDBObject(attr, true);
                    tr.Commit();
                catch (System.Exception ex)
                    ed.WriteMessage(ex.Message + "\n" + ex.StackTrace);
已领礼包: 859个
 楼主| 发表于 2014-7-27 08:12:37 | 显示全部楼层
Mark Make Blockdef
GMT+8, 2026-11-3 17:37 , Processed in 0.440548 second(s), 30 queries , Gzip On.
