查看: 1604|回复: 0
[分享] Intersect an outerloop of hatch with curves
已领礼包: 859个
发表于 2014-6-7 01:24:00 | 显示全部楼层 |阅读模式
        [CommandMethod("hat", CommandFlags.Modal)]
        public static void IntersectHatchWithCurves()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database db = doc.Database;
            Transaction tr = db.TransactionManager.StartTransaction();
            using (tr)
                try
                    BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite, false) as BlockTableRecord;
                    PromptEntityOptions peo = new PromptEntityOptions("\nSelect a hatch: ");
                    peo.SetRejectMessage("Select hatch only!");
                    peo.AddAllowedClass(typeof(Hatch), true);
                    PromptEntityResult res = doc.Editor.GetEntity(peo);
                    if (res.Status != PromptStatus.OK) return;
                    // Point3d pt = res.PickedPoint;
                    Entity ent = tr.GetObject(res.ObjectId, OpenMode.ForRead, false) as Entity;
                    Hatch hat = ent as Hatch;
                    if (hat == null)
                        Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog("No luck, mate...");
                        return;
                    // get outer loop of hatch
                    HatchLoop loops = hat.GetLoopAt(0);
                    Polyline pline = new Polyline();
                 if (loops.IsPolyline)
                     DoubleCollection bulgcoll=new DoubleCollection();
                     Point2dCollection pts=new Point2dCollection();
                     BulgeVertexCollection bulges =  loops.Polyline;
                    for (int i=0;i<bulges.Count;i++)
                        BulgeVertex bulg = bulges;
                        bulgcoll.Add(bulg.Bulge);
                        pts.Add(bulg.Vertex);
                     // create polyline around of the hatch
                     pline = new Polyline(bulges.Count);
                    for (int n = 0; n < pts.Count; n++)
                        pline.AddVertexAt(n, pts[n], bulgcoll[n], 0, 0);
                     // commented lines used just for debug only
                    //btr.AppendEntity(pline);
                    //tr.AddNewlyCreatedDBObject(pline, true);
                    //pline.ColorIndex = 5;
                    // select all intersection curves on layer "0"
                 TypedValue[] tvs = new TypedValue[] {
              new TypedValue((int) DxfCode.Start, "arc,circle,line,lwpolyline,spline"),
              new TypedValue((int) DxfCode.LayerName, "0")
                 SelectionFilter sf = new SelectionFilter(tvs);
                 PromptSelectionOptions pso = new PromptSelectionOptions();
                    pso.MessageForRemoval="\nwrong object selected!";
                 pso.MessageForAdding = "\nSelect curves separately one by another: ";
                 PromptSelectionResult psr = ed.GetSelection(pso,sf);
                 int count = 0;
                 if (psr.Status == PromptStatus.OK)
                     count = psr.Value.GetObjectIds().Length;
                     ed.WriteMessage("\nSelected:    " + count.ToString());
                 else
                     ed.WriteMessage("\nBad selection");
                     return;
                 foreach (SelectedObject selobj in psr.Value)
                         DBObject obj = tr.GetObject(selobj.ObjectId, OpenMode.ForRead) as DBObject;
                         Curve curv = obj as Curve;
                         if (obj.ObjectId != pline.ObjectId)
                         Point3dCollection ipts = new Point3dCollection();
                         // next line is may have another syntax for other Acad release
                         pline.IntersectWith(curv, Intersect.OnBothOperands, ipts, (int)IntPtr.Zero, (int)IntPtr.Zero);
                         if (ipts.Count > 0)
                             foreach (Point3d pt in ipts)
                                 // draw circles in intersection for dispaying the result
                                 Circle circ = new Circle(pt, Vector3d.ZAxis, 0.5);
                                 btr.AppendEntity(circ);
                                 tr.AddNewlyCreatedDBObject(circ, true);
                                 circ.ColorIndex = 2;
                    tr.Commit();
                catch (Autodesk.AutoCAD.Runtime.Exception ex)
                    ed.WriteMessage("\n" + ex.Message + "\n" + ex.StackTrace);
                finally
GMT+8, 2026-11-3 07:02 , Processed in 2.463877 second(s), 28 queries , Gzip On.
