查看: 1544|回复: 0
[分享] Create associative hatch
已领礼包: 859个
发表于 2014-6-7 01:25:08 | 显示全部楼层 |阅读模式
        [CommandMethod("CreateAssocHatch","cash", CommandFlags.UsePickSet)]
        public void testCreateAssocHatch()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            ObjectId objId;
            Entity ent;
            PromptEntityResult per = ed.GetEntity(new PromptEntityOptions("\nSelect an entity to be hatched: "));
            if (per.Status != PromptStatus.OK)  return;
            objId = per.ObjectId;
            try
                Transaction tr = doc.TransactionManager.StartTransaction();
                using (tr)
                    ent = tr.GetObject(objId, OpenMode.ForRead) as Entity;
                    if (ent == null) return;
                    Hatch hat = new Hatch();
                    BlockTableRecord btr = (BlockTableRecord)tr.GetObject(SymbolUtilityServices.GetBlockModelSpaceId(db), OpenMode.ForWrite);
                   // to set associative add hatch first
                    btr.AppendEntity(hat);
                    tr.AddNewlyCreatedDBObject(hat, true);
                    hat.PatternAngle = 0.0;
                    hat.PatternScale = 10.0;
                    hat.Associative = true;
                    hat.SetHatchPattern(HatchPatternType.PreDefined, "ANSI32");
                    // append loop to hatch
                    ObjectIdCollection dbObjIds = new ObjectIdCollection();
                    dbObjIds.Add(objId);
                    hat.AppendLoop(HatchLoopTypes.External, dbObjIds);
                    hat.Layer = ent.Layer;
                    hat.ColorIndex = 256;//bylayer,  may use as per entity colorindex
                    hat.HatchStyle = HatchStyle.Normal;
                    hat.EvaluateHatch(true);
                    tr.Commit();
            catch (Autodesk.AutoCAD.Runtime.Exception ex)
                ed.WriteMessage("Error: {0}", ex.ToString());
GMT+8, 2026-11-3 13:45 , Processed in 0.504327 second(s), 28 queries , Gzip On.
