查看: 1715|回复: 1
[分享] K-d Tree for AutoCAD Point3d
已领礼包: 859个
发表于 2014-6-7 01:27:37 | 显示全部楼层 |阅读模式
Hi
This is more related to 'Data Structure' than 'Geometry' but I didn't know where to post it.
This class may be used to improve performances in case of many queries in a quite large amount of points (see here).
It targets the Framwork 4.0 to use some parallelization features.
According to the value of the 'ignoreZ' constructor argument, the resulting tree is a 2d tree (ignoreZ = true) or a 3d tree (ignoreZ = false, default).
Use ignoreZ = true if all points in the input collection lie on a plane parallel to XY or if the points have to be considered as projected on the XY plane.
The Point3dTree public methods:
NearestNeighbour(Point3d) Gets the nearest neighbour.
NearestNeighbours(Point3d, int) Gets the n nearest neighbours.
NearestNeighbours(Point3d, double) Gets the nearest neighbours within the distance.
BoxedRange(Point3d, Point3d) Gets the points in a range.
ConnectAll(double) Gets all the pairs of points which distance is less or equal than the specified distance.
The last one was was almost used for performance tests (and to reply to this challenge).          using System;
    using System.Collections.Generic;
    using System.Linq;
    using Autodesk.AutoCAD.Geometry;
    namespace PointKdTree
       /// <summary>
       /// Node of a Point3dTree
       /// </summary>
       public class TreeNode
           /// <summary>
           /// Creates a new instance of TreeNode
           /// </summary>
           /// <param name="value">The 3d point value of the node.</param>
           public TreeNode(Point3d value) { this.Value = value; }
           /// <summary>
           /// Gets the value (Point3d) of the node.
           /// </summary>
           public Point3d Value { get; internal set; }
           /// <summary>
           /// Gets the parent node.
           /// </summary>
           public TreeNode Parent { get; internal set; }
           /// <summary>
           /// Gets the left child node.
           /// </summary>
           public TreeNode LeftChild { get; internal set; }
           /// <summary>
           /// Gets the right child node.
           /// </summary>
           public TreeNode RightChild { get; internal set; }
           /// <summary>
           /// Gets the depth of the node in tree.
           /// </summary>
           public int Depth { get; internal set; }
           /// <summary>
           /// Gets a value indicating if the current node is a LeftChild node.
           /// </summary>
           public bool IsLeft { get; internal set; }
       /// <summary>
       /// Provides methods to organize 3d points in a Kd tree structure to speed up the search of neighbours.
       /// A boolean constructor parameter (ignoreZ) indicates if the resulting Kd tree is a 3d tree or a 2d tree.
       /// Use ignoreZ = true if all points in the input collection lie on a plane parallel to XY
       /// or if the points have to be considered as projected on the XY plane.
       /// </summary>
       public class Point3dTree
           #region Private fields
           private int dimension;
           private int parallelDepth;
           private bool ignoreZ;
           private Func<Point3d, Point3d, double> sqrDist;
           #endregion
           #region Constructor
           /// <summary>
           /// Creates an new instance of Point3dTree.
           /// </summary>
           /// <param name="points">The Point3d collection to fill the tree.</param>
           /// <param name="ignoreZ">A value indicating if the Z coordinate of points is ignored
           /// (as if all points were projected to the XY plane).</param>
           public Point3dTree(IEnumerable<Point3d> points, bool ignoreZ = false)
               if (points == null)
                   throw new ArgumentNullException("points");
               this.ignoreZ = ignoreZ;
               this.dimension = ignoreZ ? 2 : 3;
               if (ignoreZ)
                   this.sqrDist = SqrDistance2d;
               else
                   this.sqrDist = SqrDistance3d;
               int numProc = System.Environment.ProcessorCount;
               this.parallelDepth = -1;
               while (numProc >> ++this.parallelDepth > 1) ;
               Point3d[] pts = points.Distinct().ToArray();
               this.Root = Create(pts, 0, null, false);
           #endregion
           #region Public properties
           /// <summary>
           /// Gets the root node of the tree.
           /// </summary>
           public TreeNode Root { get; private set; }
           #endregion
           #region Public methods
           /// <summary>
           /// Gets the nearest neighbour.
           /// </summary>
           /// <param name="point">The point from which search the nearest neighbour.</param>
           /// <returns>The nearest point in the collection from the specified one.</returns>
           public Point3d NearestNeighbour(Point3d point)
               return GetNeighbour(point, this.Root, this.Root.Value, double.MaxValue);
           /// <summary>
           /// Gets the neighbours within the specified distance.
           /// </summary>
           /// <param name="point">The point from which search the nearest neighbours.</param>
           /// <param name="radius">The distance in which collect the neighbours.</param>
           /// <returns>The points which distance from the specified point is less or equal to the specified distance.</returns>
           public Point3dCollection NearestNeighbours(Point3d point, double radius)
               Point3dCollection points = new Point3dCollection();
               GetNeighboursAtDistance(point, radius * radius, this.Root, points);
               return points;
           /// <summary>
           /// Gets the given number of nearest neighbours.
           /// </summary>
           /// <param name="number">The number of points to collect.</param>
           /// <returns>The n nearest neighbours of the specified point.</returns>
           public Point3dCollection NearestNeighbours(Point3d point, int number)
               List<Tuple<double, Point3d>> pairs = new List<Tuple<double, Point3d>>(number);
               GetKNeighbours(point, number, this.Root, pairs);
               for (int i = 0; i < pairs.Count; i++)
                   points.Add(pairs.Item2);
               return points;
           /// <summary>
           /// Gets the points in a range.
           /// </summary>
           /// <param name="pt1">The first corner of range.</param>
           /// <param name="pt2">The opposite corner of the range.</param>
           /// <returns>All points within the box.</returns>
           public Point3dCollection BoxedRange(Point3d pt1, Point3d pt2)
               Point3d lowerLeft = new Point3d(
                   Math.Min(pt1.X, pt2.X), Math.Min(pt1.Y, pt2.Y), Math.Min(pt1.Z, pt2.Z));
               Point3d upperRight = new Point3d(
                   Math.Max(pt1.X, pt2.X), Math.Max(pt1.Y, pt2.Y), Math.Max(pt1.Z, pt2.Z));
               FindRange(lowerLeft, upperRight, this.Root, points);
               return points;
           /// <summary>
           /// Gets all the pairs of points which distance is less or equal than the specified distance.
           /// </summary>
           /// <param name="radius">The maximum distance between two points. </param>
           /// <returns>The pairs of points which distance is less or equal than the specified distance.</returns>
           public List<Tuple<Point3d, Point3d>> ConnectAll(double radius)
               List<Tuple<Point3d, Point3d>> connexions = new List<Tuple<Point3d, Point3d>>();
               GetConnexions(this.Root, radius * radius, connexions);
               return connexions;
           #endregion
           #region Private methods
           private TreeNode Create(Point3d[] points, int depth, TreeNode parent, bool isLeft)
               int length = points.Length;
               if (length == 0) return null;
               int d = depth % this.dimension;
               Point3d median = points.QuickSelectMedian((p1, p2) => p1[d].CompareTo(p2[d]));
               TreeNode node = new TreeNode(median);
               node.Depth = depth;
               node.Parent = parent;
               node.IsLeft = isLeft;
               int mid = length / 2;
               int rlen = length - mid - 1;
               Point3d[] left = new Point3d[mid];
               Point3d[] right = new Point3d[rlen];
               Array.Copy(points, 0, left, 0, mid);
               Array.Copy(points, mid + 1, right, 0, rlen);
               if (depth < this.parallelDepth)
                   System.Threading.Tasks.Parallel.Invoke(
                      () => node.LeftChild = Create(left, depth + 1, node, true),
                      () => node.RightChild = Create(right, depth + 1, node, false)
               else
                   node.LeftChild = Create(left, depth + 1, node, true);
                   node.RightChild = Create(right, depth + 1, node, false);
               return node;
           private Point3d GetNeighbour(Point3d center, TreeNode node, Point3d currentBest, double bestDist)
               if (node == null)
                   return currentBest;
               Point3d current = node.Value;
               int d = node.Depth % this.dimension;
               double coordCen = center[d];
               double coordCur = current[d];
               double dist = this.sqrDist(center, current);
               if (dist >= 0.0 && dist < bestDist)
                   currentBest = current;
                   bestDist = dist;
               dist = coordCen - coordCur;
               if (bestDist < dist * dist)
                   currentBest = GetNeighbour(
                       center, coordCen < coordCur ? node.LeftChild : node.RightChild, currentBest, bestDist);
                   bestDist = this.sqrDist(center, currentBest);
               else
                   currentBest = GetNeighbour(center, node.LeftChild, currentBest, bestDist);
                   currentBest = GetNeighbour(center, node.RightChild, currentBest, bestDist);
               return currentBest;
           private void GetNeighboursAtDistance(Point3d center, double radius, TreeNode node, Point3dCollection points)
               if (node == null) return;
               if (dist <= radius)
                   points.Add(current);
               if (dist * dist > radius)
                   if (coordCen < coordCur)
                       GetNeighboursAtDistance(center, radius, node.LeftChild, points);
                   else
                       GetNeighboursAtDistance(center, radius, node.RightChild, points);
               else
           private void GetKNeighbours(Point3d center, int number, TreeNode node, List<Tuple<double, Point3d>> pairs)
               int cnt = pairs.Count;
               if (cnt == 0)
                   pairs.Add(new Tuple<double, Point3d>(dist, current));
               else if (cnt < number)
                   if (dist > pairs[0].Item1)
                       pairs.Insert(0, new Tuple<double, Point3d>(dist, current));
                   else
               else if (dist < pairs[0].Item1)
                   pairs[0] = new Tuple<double, Point3d>(dist, current);
                   pairs.Sort((p1, p2) => p2.Item1.CompareTo(p1.Item1));
               if (dist * dist > pairs[0].Item1)
                       GetKNeighbours(center, number, node.LeftChild, pairs);
                   else
                       GetKNeighbours(center, number, node.RightChild, pairs);
               else
           private void FindRange(Point3d lowerLeft, Point3d upperRight, TreeNode node, Point3dCollection points)
               if (node == null)
                   return;
               if (ignoreZ)
                   if (current.X >= lowerLeft.X && current.X <= upperRight.X &&
                       current.Y >= lowerLeft.Y && current.Y <= upperRight.Y)
               else
                       current.Y >= lowerLeft.Y && current.Y <= upperRight.Y &&
                       current.Z >= lowerLeft.Z && current.Z <= upperRight.Z)
               if (upperRight[d] < current[d])
                   FindRange(lowerLeft, upperRight, node.LeftChild, points);
               else if (lowerLeft[d] > current[d])
                   FindRange(lowerLeft, upperRight, node.RightChild, points);
               else
           private void GetConnexions(TreeNode node, double radius, List<Tuple<Point3d, Point3d>> connexions)
               Point3d center = node.Value;
               if (ignoreZ)
               GetRightParentsNeighbours(center, node, radius, points);
               for (int i = 0; i < points.Count; i++)
                   connexions.Add(new Tuple<Point3d, Point3d>(center, points));
               GetConnexions(node.LeftChild, radius, connexions);
               GetConnexions(node.RightChild, radius, connexions);
           private void GetRightParentsNeighbours(Point3d center, TreeNode node, double radius, Point3dCollection points)
               TreeNode parent = GetRightParent(node);
               if (parent == null) return;
               int d = parent.Depth % this.dimension;
               double dist = center[d] - parent.Value[d];
               if (dist * dist <= radius)
                   GetNeighboursAtDistance(center, radius, parent.RightChild, points);
               GetRightParentsNeighbours(center, parent, radius, points);
           private TreeNode GetRightParent(TreeNode node)
               TreeNode parent = node.Parent;
               if (parent == null) return null;
               if (node.IsLeft) return parent;
               return GetRightParent(parent);
           private double SqrDistance2d(Point3d p1, Point3d p2)
               return (p1.X - p2.X) * (p1.X - p2.X) +
                   (p1.Y - p2.Y) * (p1.Y - p2.Y);
           private double SqrDistance3d(Point3d p1, Point3d p2)
                   (p1.Y - p2.Y) * (p1.Y - p2.Y) +
                   (p1.Z - p2.Z) * (p1.Z - p2.Z);
           #endregion
       static class Extensions
           // Credit: Tony Tanzillo
           // http://www.theswamp.org/index.php?topic=44312.msg495808#msg495808
           public static T QuickSelectMedian<T>(this T[] items, Comparison<T> compare)
               int l = items.Length;
               int k = l / 2;
               if (items == null || l == 0)
                   throw new ArgumentException("array");
               int from = 0;
               int to = l - 1;
               while (from < to)
                   int r = from;
                   int w = to;
                   T current = items[(r + w) / 2];
                   while (r < w)
                       if (compare(items[r], current) > -1)
                           var tmp = items[w];
                           items[w] = items[r];
                           items[r] = tmp;
                           w--;
                       else
                           r++;
                   if (compare(items[r], current) > 0)
                       r--;
                   if (k <= r)
                       to = r;
                   else
                       from = r + 1;
               return items[k];
已领礼包: 859个
 楼主| 发表于 2014-6-7 15:21:39 来自手机 | 显示全部楼层
二叉树搜索,高飞版主写过一个lisp版的构建和查找
GMT+8, 2026-11-3 01:54 , Processed in 0.451122 second(s), 30 queries , Gzip On.
