查看: 1557|回复: 1
[分享] Count total length using LINQ
已领礼包: 859个
发表于 2014-6-7 02:54:47 | 显示全部楼层 |阅读模式
        //using System.Linq;
        [CommandMethod("TotalLengthCS")]
        public void testTotalLengthCS()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database db = doc.Database;
            StringBuilder sb = new StringBuilder();
            sb.AppendLine("\tTotal Length:\n------------------------------------");
            try
                using (Transaction tr = db.TransactionManager.StartTransaction())
                    // Create filter object, this filter can have any types to select, i.e. curves
                    SelectionFilter filter = new SelectionFilter(new TypedValue[]
                         new TypedValue(0, "LINE,ARC,SPLINE,CIRCLE,ELLIPSE,*POLYLINE") /*, new TypedValue(410, "~Model"),//<-- paper space only//*/
                    // Select objects on screen
                    PromptSelectionResult psr = ed.GetSelection(filter);
                    // Check if selection is succeed
                    if (psr.Status != PromptStatus.OK) return;
                    // See here for more: http://code.msdn.microsoft.com/101-LINQ-Samples-3fb9811b        101 LINQ Samples Csharp
        // Grouping objects by name with sum of lengths
                       var data =
                            from e in psr.Value.GetObjectIds()
                            let ln= e.GetObject(OpenMode.ForRead) as Curve
                            group ln by ln.GetRXClass().DxfName into g
                            select new { ObjectName = g.Key, Subtotal = g.Sum(x => Math.Abs(x.GetDistanceAtParameter(x.EndParam - x.StartParam))) };
                    foreach (var n in data)
                        sb.AppendLine(string.Format("{0}\t{1:f6}", n.ObjectName, n.Subtotal));
                    System.Windows.Forms.MessageBox.Show(sb.ToString());
            catch (System.Exception ex)
                System.Windows.Forms.MessageBox.Show(ex.ToString());
已领礼包: 859个
 楼主| 发表于 2014-6-7 14:02:36 来自手机 | 显示全部楼层
标记一个 linq
GMT+8, 2026-11-3 10:16 , Processed in 0.378373 second(s), 29 queries , Gzip On.
