查看: 1244|回复: 0
[分享] A reliable way to select the entities with ed.Getentity method
已领礼包: 859个
发表于 2014-6-7 02:56:27 | 显示全部楼层 |阅读模式
              public static ErrorStatus fixoGetEntity(Transaction tr, Editor ed, RXClass rx, string msg, out ObjectId id)
            ErrorStatus es;
            Entity ent;
            id = ObjectId.Null;
            PromptEntityOptions peo = new PromptEntityOptions(msg);
            peo.SetRejectMessage("\nYou're missing, try again >>");
            peo.AddAllowedClass(typeof(Entity), false);
            PromptEntityResult res;
            res = ed.GetEntity(peo);
            if (res.Status != PromptStatus.OK)
                es = ErrorStatus.PointNotOnEntity;
            id = res.ObjectId;
            if (id == ObjectId.Null)
                es = ErrorStatus.NullObjectId;
            ent = tr.GetObject(id, OpenMode.ForRead, false) as Entity;
            if (ent.GetRXClass() != rx)
                ed.WriteMessage("\n{0}Must be a \"{0}\" type of only!",rx.DxfName);
                es = ErrorStatus.NotThatKindOfClass;
            if (ent == null)
                es = ErrorStatus.NotAnEntity;
            else es = ErrorStatus.OK;
            return es;
        // Use function above this way
        [CommandMethod("tef")]
        public static void testSelectFunction()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database db = doc.Database;
            ObjectId id = ObjectId.Null;
            using (Transaction tr = db.TransactionManager.StartTransaction())
               if (fixoGetEntity(tr, ed, RXClass.GetClass(typeof(MText)), "\nSelect MTEXT to edit", out id) == ErrorStatus.OK)
                    ed.WriteMessage("\nObjectId: {0}\n", id);
                    ed.WriteMessage("\nEntity Name: {0}\n", id.ObjectClass.DxfName);
                    // get entity by direct cast
                    Entity ent = (Entity)tr.GetObject(id, OpenMode.ForWrite);
                    ent.ColorIndex = 121;// do whatever you need with entity here
                    tr.Commit();
GMT+8, 2026-11-3 10:17 , Processed in 0.386015 second(s), 28 queries , Gzip On.
