查看: 1514|回复: 0
[分享] Copy selected objects to other document
已领礼包: 859个
发表于 2014-6-7 03:02:17 | 显示全部楼层 |阅读模式
        //using System.Windows.Forms;
        static public void createCopyDoc(string fileName) // This method can have any name
            DocumentCollection dm = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager;
            Document doc = dm.MdiActiveDocument;
            try
            using (DocumentLock docloc = doc.LockDocument())
                if (!File.Exists(fileName))
                    Document newdoc = dm.Add("");
                    Database newdb=newdoc.Database;
                    newdb.SaveAs(fileName, DwgVersion.Current);
                    newdoc.CloseAndDiscard();
            catch (System.Exception ex)
                MessageBox.Show(ex.ToString());
        [CommandMethod("CSset", CommandFlags.Session)]
        static public void CopySelectedText() // This method can have any name
            string fileName = "c:\\test\\CopySet.dwg"; // add target drawing full name here
            Database db = doc.Database;
            Editor ed = doc.Editor;
            try
                Transaction tr = db.TransactionManager.StartTransaction();
                using (tr)
                    BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
                    BlockTableRecord btr = (BlockTableRecord)tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForRead);
                    // build filter to select texts and mtexts in the model space
                    TypedValue[] tv = new TypedValue[] { new TypedValue((int)DxfCode.Start, "*text"), new TypedValue(410, "Model") };
                    SelectionFilter filt = new SelectionFilter(tv);
                    //perform selection on screen
                    PromptSelectionResult res = ed.GetSelection(filt);
                    SelectionSet sset = res.Value;
                    ObjectId[] idcoll = sset.GetObjectIds();
                    ed.WriteMessage("\nSelected: {0}",  idcoll.Length);
                    ObjectIdCollection ids = new ObjectIdCollection();
                    foreach (ObjectId id in idcoll)
                        ids.Add(id);
                    } // may use ids.CopyTo(idcoll,idcoll.Length-1) instead
                    // create drawing if does not exists
                        createCopyDoc(fileName);
                    using (Database newdb = new Database(false, true))
                        newdb.ReadDwgFile(fileName,    System.IO.FileShare.ReadWrite, true, "");
                        using (Transaction newtr = newdb.TransactionManager.StartTransaction())
                           // Get Block table of target database
                            BlockTable  newbt = (BlockTable)newtr.GetObject(newdb.BlockTableId, OpenMode.ForRead);
                            // Get model space of target database
                            BlockTableRecord newbtr = (BlockTableRecord)newtr.GetObject(newbt[BlockTableRecord.ModelSpace], OpenMode.ForRead);
                        if (ids.Count != 0)
                            IdMapping iMap = new IdMapping();
                            db.WblockCloneObjects(ids, newbtr.ObjectId, iMap, DuplicateRecordCloning.Ignore, false);
                            // Save target drawing
                            newdb.SaveAs(fileName, DwgVersion.Current);// [A2010] this syntax ought be different for other Acad release
                    tr.Commit();
                }//end using transaction
                // informative message
                ed.WriteMessage("\n{0}\n", ex.ToString());
GMT+8, 2026-11-3 10:17 , Processed in 0.394746 second(s), 28 queries , Gzip On.
