查看: 1736|回复: 1
[分享] Simple numbering suit with prefix
已领礼包: 859个
发表于 2014-6-7 03:04:37 | 显示全部楼层 |阅读模式
#region Imports
// Microsoft
using System;
using System.Collections.Generic;
using System.Text;
// Autodesk
using acadApp = Autodesk.AutoCAD.ApplicationServices.Application;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.Geometry;
#endregion
[assembly: CommandClass(typeof(MyTextPlugin.TextCommands))]
namespace MyTextPlugin
    public class TextCommands
        [CommandMethod("NumPrefix")]
        static public void NumberingWithPrefix()
            Document doc = acadApp.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database db = doc.Database;
            try
                using (Transaction tr = db.TransactionManager.StartTransaction())
                    PromptStringOptions pso = new PromptStringOptions("\nEnter a Prefix : ");
                    pso.AllowSpaces = true;
                    pso.UseDefaultValue = true;
                    pso.DefaultValue = "AB";
                    PromptResult res;
                    string pfx = string.Empty;
                    res = ed.GetString(pso);
                    if (res.Status == PromptStatus.OK)
                        pfx = res.StringResult;
                    if (res.Status == PromptStatus.None)
                        pfx = "AB";
                    int num = new Int32();
                    PromptIntegerOptions pio = new PromptIntegerOptions("");
                    pio.Message = "\nEnter a Starting Number: ";
                    // Restrict input to positive and non-negative or non-zero values
                    pio.AllowZero = false;
                    pio.AllowNegative = false;
                    // Add default value
                    pio.DefaultValue = 1;
                    // Allow user the empty input by press Enter key
                    pio.AllowNone = true;
                    // Get the value entered by the user
                    PromptIntegerResult ires = ed.GetInteger(pio);
                    if (ires.Status == PromptStatus.OK)
                        num = ires.Value;
                    if (ires.Status == PromptStatus.None)
                        num = 1;
                    int inc = new Int32();
                    pio.Message = "\nEnter an Increment Number by: ";
                        inc = ires.Value;
                        inc = 1;
                    double hgt = new double();
                    PromptDoubleOptions pdo = new PromptDoubleOptions("\nEnter a Text Height: ");
                    pdo.AllowNone = true;
                    pdo.AllowZero = false;
                    pdo.AllowNegative = false;
                    pdo.UseDefaultValue = true;
                    pdo.DefaultValue = 1.0; // may be db.Textsize or other default
                    pdo.Message = "\nEnter a text height: ";
                    PromptDoubleResult dres;
                    dres = ed.GetDouble(pdo);
                    if (dres.Status == PromptStatus.None)
                        hgt = 1.0;
                    if (dres.Status == PromptStatus.OK)
                        hgt = dres.Value;
                    BlockTableRecord btr = tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite) as BlockTableRecord;
                    Point3d pt = new Point3d();
                    Point3d npt = new Point3d();
                    bool first = GetFirstPoint(ed, "Select text location: ", out pt);
                    DBText txt = new DBText();
                    txt.SetDatabaseDefaults();
                    txt.Position = pt;
                    txt.Height = hgt;
                    txt.TextString = pfx + num.ToString();
                    //Set justification to middle center:
                    txt.VerticalMode = TextVerticalMode.TextVerticalMid;
                    txt.HorizontalMode = TextHorizontalMode.TextMid;
                    txt.AlignmentPoint = pt;
                    btr.AppendEntity(txt);
                    tr.AddNewlyCreatedDBObject(txt, true);
                    tr.TransactionManager.QueueForGraphicsFlush();
                    num += inc;
                    while (GetNextPoint(ed, "Select text location (or press Enter to Exit): ", pt, out npt))
                        txt = new DBText();
                        txt.Position = npt;
                        txt.Height = hgt;
                        txt.AlignmentPoint = npt;
                        pt = npt;
                        num += inc;
                    tr.Commit();
            catch (System.Exception ex)
                ed.WriteMessage("Error: ==>\n{0}\nTrace: ==>\n{1}", ex.Message, ex.StackTrace);
            finally
                //do whatever you need
        /// <summary>
        /// Custom getpoint function without base point
        /// </summary>
        /// <param name="ed">document editor</param>
        /// <param name="pt">Point3d, by reference</param>
        /// <returns>Return true if success</returns>
        public static bool GetFirstPoint(Editor ed, string msg, out Point3d pt)
            pt = new Point3d();
            PromptPointOptions opt = new PromptPointOptions("\n" + msg);
            PromptPointResult res = ed.GetPoint(opt);
                pt = res.Value;
                return true;
            else
                return false;
        /// <summary>
        /// Custom getpoint function with base point
        /// </summary>
        /// <param name="msg">string, user prompt</param>
        /// <param name="frompt">Point3d, by value</param>
        /// <returns>Return true if succes</returns>
        public static bool GetNextPoint(Editor ed, string msg, Point3d frompt, out Point3d pt)
            pt = new Point3d();
            opt.UseBasePoint = false;
            opt.UseDashedLine = false;
            opt.AllowNone = true;
            opt.BasePoint = frompt;
                pt = res.Value;
                return true;
            else
                return false;
已领礼包: 859个
 楼主| 发表于 2014-12-9 10:38:56 | 显示全部楼层
Mark
tr.Commit();
GMT+8, 2026-11-3 00:52 , Processed in 0.581131 second(s), 30 queries , Gzip On.
