查看: 1714|回复: 1
[分享] Change the background mask property of AcDbMText object programmatically
已领礼包: 859个
发表于 2014-6-7 03:07:24 | 显示全部楼层 |阅读模式
        public static ErrorStatus fixoGetEntity(Transaction tr, Editor ed, RXClass rx, string msg, out ObjectId id)
            ErrorStatus es;
            Entity ent;
            id = ObjectId.Null;
            PromptEntityOptions peo = new PromptEntityOptions(msg);
            peo.SetRejectMessage("\nYou're missing, try again >>");
            peo.AddAllowedClass(typeof(Entity), false);
            PromptEntityResult res;
            res = ed.GetEntity(peo);
            if (res.Status != PromptStatus.OK)
                es = ErrorStatus.PointNotOnEntity;
            id = res.ObjectId;
            if (id == ObjectId.Null)
                es = ErrorStatus.NullObjectId;
            ent = tr.GetObject(id, OpenMode.ForRead, false) as Entity;
            if (ent.GetRXClass() != rx)
                ed.WriteMessage("\n{0}Must be a type of \"{0}\" only!", rx.DxfName);
                es = ErrorStatus.NotThatKindOfClass;
            if (ent == null)
                es = ErrorStatus.NotAnEntity;
            else es = ErrorStatus.OK;
            return es;
        [CommandMethod("BM")]
        static public void test_setBackgroundFill_MText()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database db = HostApplicationServices.WorkingDatabase;
            ObjectId id = ObjectId.Null;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                if (fixoGetEntity(tr, ed, RXClass.GetClass(typeof(MText)), "\nPlease pick an MText entity: ", out id) == ErrorStatus.OK)
                    BlockTableRecord btr = tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite) as BlockTableRecord;
                   // get entity by direct cast
                    Entity ent = (Entity)tr.GetObject(id, OpenMode.ForRead);
                    if (id.ObjectClass.DxfName == "MTEXT")
                        MText mtx = ent as MText;
                        mtx.UpgradeOpen();
                        Autodesk.AutoCAD.Colors.Color color;
                        if (mtx.BackgroundFill )
                            mtx.UseBackgroundColor= false;
                            mtx.BackgroundFill=false;
                        else
                            mtx.BackgroundFill=true;
                            color = Color.FromColorIndex(ColorMethod.ByAci, (int)1);
                            mtx.BackgroundFillColor = color;
                            mtx.UseBackgroundColor=false;
                        mtx.RecordGraphicsModified(true);
                tr.Commit();
发表于 2014-6-7 18:39:11 | 显示全部楼层
很好的例程,也可以作为WipeOut的一种实现方式
GMT+8, 2026-11-3 01:52 , Processed in 0.405437 second(s), 30 queries , Gzip On.
