查看: 1626|回复: 1
[分享] Osnap Palette
已领礼包: 859个
发表于 2014-6-7 03:09:38 | 显示全部楼层 |阅读模式
    using System;
    using Autodesk.AutoCAD.Runtime;
    using Autodesk.AutoCAD.Windows;
    namespace OsnapPalette
        public class OsPalette
            static PaletteSet ps;
            internal static OsmodeControl osmCtrl;
            public OsPalette()
                osmCtrl = new OsmodeControl();
            public void Show()
                if (ps == null)
                    ps = new PaletteSet("OSPALETTE", new Guid("{379AD059-A26C-4a3b-A05C-313A799D48CA}"));
                    ps.Style =
                      PaletteSetStyles.ShowPropertiesMenu |
                      PaletteSetStyles.ShowAutoHideButton |
                      PaletteSetStyles.ShowCloseButton;
                    ps.Name = "Accrochages aux objets";
                    ps.MinimumSize = new System.Drawing.Size(300, 340);
                    ps.Add("Accrobj", osmCtrl);
                ps.Visible = true;
            [CommandMethod("OSPALETTE")]
            public void Accobj()
                this.Show();
已领礼包: 859个
 楼主| 发表于 2014-6-7 03:10:11 | 显示全部楼层
    using System;
    using System.Collections.Generic;
    using System.Windows.Forms;
    using Autodesk.AutoCAD.ApplicationServices;
    using AcAp = Autodesk.AutoCAD.ApplicationServices.Application;
    using AcAs = Autodesk.AutoCAD.ApplicationServices;
        public partial class OsmodeControl : UserControl
            private Dictionary<int, CheckBox> modes = new Dictionary<int, CheckBox>();
            public OsmodeControl()
                InitializeComponent();
                modes.Add(1, this.chkEnd);
                modes.Add(2, this.chkMid);
                modes.Add(4, this.chkCen);
                modes.Add(8, this.chkNod);
                modes.Add(16, this.chkQua);
                modes.Add(32, this.chkInt);
                modes.Add(64, this.chkIns);
                modes.Add(128, this.chkPer);
                modes.Add(256, this.chkTan);
                modes.Add(512, this.chkNea);
                modes.Add(2048, this.chkPrj);
                modes.Add(4096, this.chkExt);
                modes.Add(8192, this.chkPar);
                InitCheckBoxes();
                AcAp.SystemVariableChanged +=
                    new AcAs.SystemVariableChangedEventHandler(AcAp_SysvarChanged);
            void AcAp_SysvarChanged(object sender, AcAs.SystemVariableChangedEventArgs e)
                if (e.Name == "OSMODE" || e.Name == "AUTOSNAP")
                    InitCheckBoxes();
            private void InitCheckBoxes()
                short osmode = (short)AcAp.GetSystemVariable("OSMODE");
                foreach (KeyValuePair<int, CheckBox> pair in modes)
                    pair.Value.Checked = (osmode & pair.Key) == pair.Key;
                this.chkF3.Checked = (osmode & 16384) == 0;
                this.chkF11.Checked = (((short)AcAp.GetSystemVariable("AUTOSNAP")) & 16) == 16;
            private void cmdAll_Click(object sender, EventArgs e)
                foreach (KeyValuePair<int,CheckBox> pair in modes)
                    pair.Value.Checked = true;
            private void cmdNone_Click(object sender, EventArgs e)
                    pair.Value.Checked = false;
            private void OsmodeControl_MouseLeave(object sender, EventArgs e)
                Document doc = AcAp.DocumentManager.MdiActiveDocument;
                int autosnap = (short)AcAp.GetSystemVariable("AUTOSNAP");
                autosnap = chkF11.Checked ? autosnap | 16 : autosnap - (autosnap & 16);
                int osmode = 0;
                    if (pair.Value.Checked)
                        osmode += pair.Key;
                if (!chkF3.Checked)
                    osmode += 16384;
                using (DocumentLock docLock = doc.LockDocument())
                    AcAp.SetSystemVariable("OSMODE", osmode);
                    AcAp.SetSystemVariable("AUTOSNAP", autosnap);
GMT+8, 2026-11-3 03:10 , Processed in 0.423888 second(s), 30 queries , Gzip On.
