查看: 1360|回复: 2
[分享] NumerixBox and IntegerBox
已领礼包: 859个
发表于 2014-6-7 03:11:55 | 显示全部楼层 |阅读模式
NumericBox and IntegerBox. (EDIT: added an AngleBox)
These two three little classes can be added to a project to add new controls.
They inhertit from TextBox and have some specfic properties and overload methods to insure valid values.
An ErrorProvider is used in case of non valid entry.
Specific properties are available in the Visual Studio Properties window for the control instance.
IntegerBox
Specific properties:
- ErrorMsg: the message displayed by the ErrorProvider for incorrect value (default: "Incorrect number").
- Maximum: the maximum allowed value (default: 2147483647)
- Minimum: the minimum allowed value (default: -2147483648)
- Value: the value as integer (default 0). Setting this value overwrite the Text property.
using System;
using System.ComponentModel;
using System.Windows.Forms;
namespace ControlLibrary
    /// <summary>
    /// Defines a control that can be used to display or edit an integer.
    /// </summary>
    public class IntegerBox : TextBox
        private ErrorProvider _errorProvider;
        private int _value;
        /// <summary>
        /// Set default values.
        /// </summary>
        public IntegerBox()
            _errorProvider = new ErrorProvider();
            ErrorMsg = "Incorrect number";
            Minimum = -2147483648;
            Maximum = 2147483647;
            _value = 0;
        /// <summary>
        /// Get or set the error provider message.
        /// </summary>
        public string ErrorMsg { get; set; }
        /// <summary>
        /// Get or set the minimum allowed value.
        /// </summary>
        public int Minimum { get; set; }
        /// <summary>
        /// Get or set the maximum allowed value.
        /// </summary>
        public int Maximum { get; set; }
        /// <summary>
        /// Get or set the value as integer.
        /// </summary>
        public int Value
            get { return _value; }
            set
                _value = value;
                this.Text = _value.ToString();
                this.OnValidating(new CancelEventArgs());
        /// <summary>
        /// Evaluates if the value is a valid integer according to MinValue and MaxValue.
        /// If not, cancels the validation and displayd an error provider.
        /// </summary>
        /// <param name="e">The event data.</param>
        protected override void OnValidating(System.ComponentModel.CancelEventArgs e)
            base.OnValidating(e);
            int i;
            if (!int.TryParse(this.Text, out i) || i < Minimum || i > Maximum)
                e.Cancel = true;
                this.Select(0, this.Text.Length);
                _errorProvider.SetError(this, ErrorMsg);
        /// <summary>
        /// Updates Value.
        /// </summary>
        protected override void OnValidated(EventArgs e)
            base.OnValidated(e);
            _value = Convert.ToInt32(this.Text);
        /// <summary>
        /// Hide the error provider.
        /// </summary>
        protected override void OnTextChanged(EventArgs e)
            base.OnTextChanged(e);
            _errorProvider.SetError(this, "");
已领礼包: 859个
 楼主| 发表于 2014-6-7 03:12:39 | 显示全部楼层
NumericBox
- DecimalPlaces: the number of digits displayed in the box after validation (default 0)
- Value: the value as double (default 0.0). Setting this value overwrite the Text property. This value may be more accurate than the displayed one.
using System;
    /// <summary>
    /// Defines a control that can be used to display or edit a real number (double).
    /// </summary>
    public class NumericBox : TextBox
        private double _value;
        private int _decimalPlaces;
        protected string _stringFormat;
        /// <summary>
        /// </summary>
        public NumericBox()
            _value = 0;
            SetFormat();
        /// <summary>
        /// Get or set the number of digits diplayed in the box.
        /// </summary>
        public int DecimalPlaces
            get { return _decimalPlaces; }
            set { _decimalPlaces = value; SetFormat(); }
        /// <summary>
        /// Get or set the ErrorProvider message.
        /// </summary>
        /// <summary>
        /// Get or set the number value as double (may be more accurate than the displayed one).
        /// Updates the Text according to DecimalPlaces.
        /// </summary>
        public virtual double Value
            set {  _value = value;  this.Text = _value.ToString(_stringFormat); }
        /// <summary>
        /// Evaluates if the value is a valid real number.
        /// If not, cancels the validation and displayd the ErrorProvider icon.
        /// </summary>
        /// <param name="e">The event data</param>
        protected override void OnValidating(CancelEventArgs e)
            double d;
            if (!double.TryParse(this.Text, out d))
                e.Cancel = true;
        /// <summary>
        /// Updates Text and Value.
        /// </summary>
            _value = Convert.ToDouble(this.Text);
        /// <summary>
        /// Hide the ErrorProvider icon.
        /// </summary>
        /// <summary>
        /// Creates a format string according to DecimalPlaces value.
        /// Updates the Format property.
        /// </summary>
        private void SetFormat()
            if (DecimalPlaces < 1)
                _stringFormat = "0";
            else
                _stringFormat = "0.";
                for (int i = 0; i < DecimalPlaces; i++) _stringFormat += "0";
已领礼包: 859个
 楼主| 发表于 2014-6-7 03:13:19 | 显示全部楼层
AngleBox (inherits from NumericBox)
Specific Property:
- UnitFormat: the unit format for the Text displayed. The Value property is always expressed in radians.
using System;
    /// <summary>
    /// Defines a control that can be used to display or edit an angular value (double).
    /// </summary>
    public class AngleBox : NumericBox
        /// <summary>
        /// Angular units enumeration.
        /// </summary>
        public enum Unit
            Degree,
            Grade,
            Radian
        /// <summary>
        /// Define the default angular unit.
        /// </summary>
        public AngleBox()
            this.UnitFormat = Unit.Degree;
        /// <summary>
        /// Get or set the angular format (unit).
        /// </summary>
        public Unit UnitFormat { get; set; }
        /// <summary>
        /// Get or set the angle value in radians.
        /// Updates the Text property according to UnitFormat and DecimalPlaces.
        /// </summary>
        public override double Value
            set { _value = value; this.Text = AngleToString(_value); }
        /// <summary>
        /// Updates Text and Value properties.
        /// </summary>
            _value = StringToAngle(this.Text);
        /// <summary>
        /// Converts a string into an angle value in radians.
        /// </summary>
        /// <param name="txt">The angle expressed according to UnitFormat.</param>
        /// <returns>The angle value in radians.</returns>
        private double StringToAngle(string txt)
            switch (UnitFormat)
                case Unit.Degree:
                    return Convert.ToDouble(txt) * Math.PI / 180.0;
                case Unit.Grade:
                    return Convert.ToDouble(txt) * Math.PI / 200.0;
                default: //Radian
                    return Convert.ToDouble(txt);
        /// <summary>
        /// Converts an angle value in radians into a string.
        /// </summary>
        /// <param name="val">The angle value in radians..</param>
        /// <returns>The angle expressed according to UnitFormat</returns>
        private string AngleToString(double val)
            switch (UnitFormat)
                case Unit.Degree:
                    return (val * 180.0 / Math.PI).ToString(_stringFormat);
                case Unit.Grade:
                    return (val * 200.0 / Math.PI).ToString(_stringFormat);
                default: // Radian
                    return val.ToString(_stringFormat);
GMT+8, 2026-11-3 01:53 , Processed in 0.426970 second(s), 32 queries , Gzip On.
