查看: 1637|回复: 0
[分享] Insert block in the current table
已领礼包: 859个
发表于 2014-6-7 03:16:00 | 显示全部楼层 |阅读模式
       <CommandMethod("BlockToTable", "btin", CommandFlags.Modal)> _
        Public Shared Sub TestBlockToTable()
            Dim ver As String = Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("acadver").ToString().Substring(0, 2)
            Dim intver As Integer = Convert.ToInt32(ver)
            Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
            Dim how As Boolean = False
            Try
                Using tr As Transaction = db.TransactionManager.StartTransaction
                    Dim pso As PromptSelectionOptions = New PromptSelectionOptions
                    pso.MessageForRemoval = vbLf + "You have select the table only"
                    pso.MessageForAdding = vbLf + " Select the table: "
                    Dim entres As PromptSelectionResult
                    Dim sset As SelectionSet
                    Dim filt(0) As TypedValue
                    filt(0) = New TypedValue(DxfCode.Start, "ACAD_TABLE")
                    Dim selfilter As New SelectionFilter(filt)
                    entres = ed.GetSelection(pso, selfilter)
                    sset = entres.Value
                    If entres.Status <> PromptStatus.OK Then
                        ed.WriteMessage(vbLf + "Wrong selection!")
                        Return
                    End If
                    Dim tblid As ObjectId = entres.Value.GetObjectIds(0)
                    Dim obj As Entity = tr.GetObject(tblid, OpenMode.ForRead)
                    Dim atable As Table = TryCast(obj, Table)
                    Dim pio As PromptPointOptions = New PromptPointOptions(vbLf + "Pick a cell to insert block: ")
                    Dim pres As PromptPointResult = ed.GetPoint(pio)
                    If pres.Status <> PromptStatus.OK Then
                        ed.WriteMessage(vbLf + "Invalid point specification!")
                        Return
                    End If
                    Dim pt As Point3d = pres.Value
                    Dim peo As PromptEntityOptions = New PromptEntityOptions(vbLf + "Select the single block: ")
                    Dim res As PromptEntityResult = ed.GetEntity(peo)
                    If res.Status <> PromptStatus.OK Then
                        Return
                    End If
                    Dim id As ObjectId = res.ObjectId
                    Dim ent As Entity = TryCast(tr.GetObject(id, OpenMode.ForRead), Entity)
                    If ent Is Nothing Then
                        ed.WriteMessage(vbLf + "Wrong object type selected!")
                        Return
                    End If
                    Dim bref As BlockReference = TryCast(ent, BlockReference)
                    If bref Is Nothing Then
                        ed.WriteMessage(vbLf + "Impossible to cast BlockReference from entity!")
                        Return
                    End If
                    Dim btrec As BlockTableRecord = DirectCast(tr.GetObject(bref.BlockTableRecord, OpenMode.ForRead), BlockTableRecord)
                    Dim blkid As ObjectId = btrec.ObjectId
                    Dim hit As TableHitTestInfo = atable.HitTest(pt, Vector3d.ZAxis)
                    Dim i As Integer = hit.Row
                    Dim j As Integer = hit.Column
                    If Not atable.IsWriteEnabled Then atable.UpgradeOpen()
                    '' select appropriate syntax from code block below
                    If intver = 17 Then
                        atable.SetBlockTableRecordId(i, j, blkid, True)
                    End If
                    'If intver = 18 Then
                    '    Dim c As Cell = atable.Cells(i, j)
                    '    c.Contents.Add()
                    '  c.Contents.InsertAt(0);
                    '  c.Contents(0).BlockTableRecordId =  blockId;
                    'Else
                    '    Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog("Change a syntax accordingly to the current version")
                    'End If
                    atable.RecomputeTableBlock(True)
                    how = True
                    tr.Commit()
                End Using
            Catch ex As Autodesk.AutoCAD.Runtime.Exception
                ed.WriteMessage(ex.Message + vbLf + ex.StackTrace)
                how = False
            Catch ex As System.Exception
                how = False
            Finally
                Dim result As String = "   ---   The program has ended up with " + IIf(how, "success", "bug").ToString
                ed.WriteMessage(vbLf + result)
            End Try
        End Sub
GMT+8, 2026-11-3 01:52 , Processed in 0.509729 second(s), 28 queries , Gzip On.
