查看: 1469|回复: 1
[分享] Get the MText object in a cell
已领礼包: 859个
发表于 2014-6-7 03:17:04 | 显示全部楼层 |阅读模式
using System.Linq;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
namespace TableSample
    static class Extensions
        // Retourne l'objet MText contenu dans la cellule (ou null s'il nexiste pas).
        // Returns the MText object contained in the cell (or null if it don't exist).
        public static MText GetMtext(this Cell cell)
            Table table = cell.ParentTable;
            Extents3d extents = cell.GetExtents().ToExtents3d();
            extents.TransformBy(table.BlockTransform.Inverse());
            BlockTableRecord btr = (BlockTableRecord)table.BlockTableRecord.GetObject(OpenMode.ForRead);
            RXClass mtextClass = RXClass.GetClass(typeof(MText));
            foreach (ObjectId id in btr)
                if (id.ObjectClass == mtextClass)
                    MText mtext = (MText)id.GetObject(OpenMode.ForRead);
                    if (mtext.Location.IsInside(extents))
                        return mtext;
            return null;
        // Evalue si un point est à l'intérieur de la boite (BoundingBox).
        // Evaluates if the point is within the extents (BoundingBox).
        private static bool IsInside(this Point3d pt, Extents3d extents)
            return
                pt.X >= extents.MinPoint.X &&
                pt.Y >= extents.MinPoint.Y &&
                pt.Z >= extents.MinPoint.Z &&
                pt.X <= extents.MaxPoint.X &&
                pt.Y <= extents.MaxPoint.Y &&
                pt.Z <= extents.MaxPoint.Z;
        // Retourne la boite (BoundingBox) définie par la collection de points.
        // Returns the extents (BoundingBox) defined by the points collection
        private static Extents3d ToExtents3d(this Point3dCollection pts)
            return pts.Cast<Point3d>()
                .Aggregate(new Extents3d(pts[0], pts[0]), (ext, pt) =>
                { ext.AddPoint(pt); return ext; });
已领礼包: 859个
 楼主| 发表于 2014-6-7 03:17:37 | 显示全部楼层
In AutoCAD 2010 it might be resolved like this
Cell cell = mytable.Cells[row, column];
string celltext = cell.GetTextString(FormatOption.IgnoreMtextFormat);
GMT+8, 2026-11-3 06:03 , Processed in 0.516674 second(s), 30 queries , Gzip On.
