查看: 1237|回复: 0
[分享] Create ordinate dimension
已领礼包: 859个
发表于 2014-6-7 03:18:45 | 显示全部楼层 |阅读模式
       [CommandMethod("CreateOrdinateDimension","cdom", CommandFlags.Modal | CommandFlags.UsePickSet)]
        public static void testOrdinateDimension()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database db = doc.Database;
            ObjectId id = ObjectId.Null;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                PromptPointOptions ppo = new PromptPointOptions("\n  >>  Select point for ordinate dimension >>");
                PromptPointResult ppr = ed.GetPoint(ppo);
                if (ppr.Status != PromptStatus.OK) return;
                double gap = db.Dimtxt * 2;
               Point3d  pt = ppr.Value;
               Point3d tpt = new Point3d(pt.X, pt.Y + gap, pt.Z);
               Matrix3d mx = ed.CurrentUserCoordinateSystem.Inverse();
               Vector3d mXPrev = Vector3d.XAxis;
                // build custom dimension text
               string dstr = string.Format("X = {0:f3}\\PY = {1:f3}", pt.X, pt.Y);// set precision to 3 decimals {:f3}
               OrdinateDimension odim = new OrdinateDimension(false, pt, tpt, dstr, db.Dimstyle);
               double ohrot = odim.HorizontalRotation;
               // get the old Xaxis and transform it to current plane
               Matrix3d mMat = Matrix3d.PlaneToWorld(odim.Normal); //ECS
               mXPrev.TransformBy(mMat); //get the ECS xaxis in the world coordinates
               mXPrev.TransformBy(mx); //transform current xaxis to plane defined by mx
               // transform the dimension entity by the given transformation matrix
               odim.TransformBy(mx);
               // get the xAxis after transformation of the dimension entity
               mMat=   Matrix3d.WorldToPlane(odim.Normal);
               // transform the old axis to the current ECS.
                  // get the angle of the old xaxis with respect to the current xaxis
                 double newhrot = - Math.Atan2(mXPrev.X, mXPrev.Y);
                 odim.HorizontalRotation = ohrot + newhrot;
               postToModelSpace(odim);
               tr.AddNewlyCreatedDBObject(odim, true);
                    tr.Commit();
        static void postToModelSpace(Entity ent)
            BlockTableRecord btr;
            Database db = HostApplicationServices.WorkingDatabase;
            btr = SymbolUtilityServices.GetBlockModelSpaceId(db).GetObject(OpenMode.ForWrite) as BlockTableRecord;
            btr.AppendEntity(ent);
GMT+8, 2026-11-3 06:04 , Processed in 0.422432 second(s), 28 queries , Gzip On.
