查看: 1326|回复: 0
[分享] Reset dimension values
已领礼包: 859个
发表于 2014-6-7 03:20:49 | 显示全部楼层 |阅读模式
    // tested on AutoCAD 2010
       [CommandMethod("ResetDimValues", "rdv", CommandFlags.Modal | CommandFlags.Redraw)]
        public void ResetDims()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database db = doc.Database;
            TypedValue[] values = new TypedValue[] { new TypedValue(0, "DIMENSION") };
            SelectionFilter filter = new SelectionFilter(values);
            PromptSelectionOptions opts = new PromptSelectionOptions();
            opts.MessageForRemoval = "\nMust be a type of Dimension!";
            opts.MessageForAdding = "\nSelect dimensions to reset : ";
            opts.PrepareOptionalDetails = false;
            opts.SingleOnly = false;
            opts.SinglePickInSpace = false;
            opts.AllowDuplicates = true;
            PromptSelectionResult result = ed.GetSelection(opts, filter);
            if (result.Status != PromptStatus.OK) return;
            try
                using (Transaction tr = db.TransactionManager.StartTransaction())
                    SelectionSet sset = result.Value;
                    foreach (SelectedObject selobj in sset)
                        DBObject obj = tr.GetObject(selobj.ObjectId, OpenMode.ForWrite, false) as DBObject;
                        Dimension dim = obj as Dimension;
                        if (dim != null)
                            dim.DimensionText = "<>";
                    tr.Commit();
            catch (System.Exception ex)
                ed.WriteMessage("\nProblem updating  dimensions.\n");
                ed.WriteMessage(ex.Message);
GMT+8, 2026-11-3 02:31 , Processed in 0.379960 second(s), 28 queries , Gzip On.
