查看: 1532|回复: 0
[分享] Move dimension text up or down
已领礼包: 859个
发表于 2014-6-7 03:21:44 | 显示全部楼层 |阅读模式
    [CommandMethod("cdimup")]
        public static void TestDimUp()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database db = HostApplicationServices.WorkingDatabase;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                // Select a dimension
                try
                    PromptEntityOptions peo = new PromptEntityOptions("\nSelect a Dimension >>");
                    peo.SetRejectMessage("\nYou have to select the Dimension only >>");
                    peo.AddAllowedClass(typeof(Dimension), false);
                    PromptEntityResult res;
                    res = ed.GetEntity(peo);
                    if (res.Status != PromptStatus.OK)
                        return;
                    Entity ent = (Entity)tr.GetObject(res.ObjectId, OpenMode.ForRead);
                    if (ent == null)
                        return;
                    Dimension dim = (Dimension)ent as Dimension;
                    if (dim == null) return;
                    if (!dim.IsWriteEnabled) dim.UpgradeOpen();
                    // Add Xdata:
                    dim.XData = new ResultBuffer(
                    new TypedValue((int)DxfCode.ExtendedDataRegAppName, "ACAD"),
                    new TypedValue((int)DxfCode.ExtendedDataAsciiString, "DSTYLE"),
                    new TypedValue((int)DxfCode.ExtendedDataControlString, "{"),
                    new TypedValue((int)DxfCode.ExtendedDataInteger16, 77),
                    new TypedValue((int)DxfCode.ExtendedDataInteger16, 1),
                    new TypedValue((int)DxfCode.ExtendedDataControlString, "}")
                    dim.DowngradeOpen();
                    tr.Commit();
                catch (System.Exception ex)
                    Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(ex.Message);
GMT+8, 2026-11-3 06:07 , Processed in 0.407926 second(s), 28 queries , Gzip On.
