查看: 1776|回复: 0
[分享] Read and parse .csv or .txt file
已领礼包: 859个
发表于 2014-6-7 03:28:59 | 显示全部楼层 |阅读模式
       [CommandMethod("ptsRead")]
        public void testReadCSV()
        {   // file name contains separated text
            string filePath = @"C:\Test\points.txt";
            if (!File.Exists(filePath))
                MessageBox.Show("File does not exist");
                return;
            // put appropriate delimiter here
            string sep = ";";
            Point3dCollection pts = new Point3dCollection();
            using (System.IO.StreamReader reader = new System.IO.StreamReader(filePath))
                while (!reader.EndOfStream)
                    // Call reader.ReadLine() appropriately
                    string textLine = reader.ReadLine();
                    Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage("\n{0}", textLine);
                    string[] tmp = textLine.Split(new string[] { sep }, StringSplitOptions.RemoveEmptyEntries);
                    if (tmp.Length != 0)
                        Point3d pt = new Point3d(Convert.ToDouble(tmp[0]), Convert.ToDouble(tmp[1]), Convert.ToDouble(tmp[2]));
                        pts.Add(pt);
            if (pts == null)
                MessageBox.Show("Cant parse this file");
                return;
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("pdmode", 34);
            Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("pdsize", 2.0);
            using (Transaction tr = db.TransactionManager.StartTransaction())
                BlockTableRecord btr = tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite) as BlockTableRecord;
                foreach (Point3d pnt in pts)
                    DBPoint pt = new DBPoint(pnt);
                    pt.SetDatabaseDefaults();
                    pt.ColorIndex = 1;// <-- set any color of point
                    btr.AppendEntity(pt);
                    DBText txt = new DBText();
                    tr.AddNewlyCreatedDBObject(pt, true);
                    txt.SetDatabaseDefaults();
                    txt.Position = pt.Position;
                    txt.TextString = txt.Position.ToString();//<-- add any textstring to suit
                    txt.Justify = AttachmentPoint.BaseLeft;
                    // txt.AlignmentPoint = pt.Position;
                    txt.AdjustAlignment(db);
                    btr.AppendEntity(txt);
                    tr.AddNewlyCreatedDBObject(txt, true);
                tr.Commit();
GMT+8, 2026-11-3 02:30 , Processed in 0.409919 second(s), 28 queries , Gzip On.
