查看: 1880|回复: 0
[分享] Extract data from drawing to xml file
已领礼包: 859个
发表于 2014-6-7 03:30:01 | 显示全部楼层 |阅读模式
     Imports System
Imports System.Text
Imports System.IO
Imports System.Data
Imports System.Reflection
Imports System.Collections.Generic
Imports System.Runtime.InteropServices
Imports System.Text.RegularExpressions
Imports System.Windows.Forms
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.Colors
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.DataExtraction
Example how to exract data into the .xml file in Debug folder
  '' based on Kean Walmsley's example from there:
        '' http://through-the-interface.typ ... xtracting-data.html
        <CommandMethod("exlines")> _
        Public Sub ExtractLines()
            Dim ed As Editor = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor
            Dim starttime As Double
            Dim endtime As Double
            Dim dialog As New System.Windows.Forms.OpenFileDialog
            With dialog
                .CheckPathExists = True
                .DefaultExt = "dxf"
                .DereferenceLinks = True
                .Multiselect = False
                .Filter = "Drawing (*.dwg)|*.dwg|All files (*.*)|*.*"
                .Title = "Select drawing"
                .FilterIndex = 1
            End With
            If dialog.ShowDialog() <> System.Windows.Forms.DialogResult.OK Then
                Return
            End If
            Dim fname As String = dialog.FileName
            starttime = DateAndTime.Timer
            Try
                ' following datatable easy to write to the any data file (Excel, Access, SQL etc)
                Dim dataTable As System.Data.DataTable = ExtractLines(fname)
                endtime = DateAndTime.Timer
                '' write data to Lines.xml in the Debug folder
               '' change the full path name of the file if you want to save it in other folder
                dataTable.WriteXml("Lines.xml")
                ed.WriteMessage(vbLf + "Elapsed time: {0:f4} seconds" + vbLf + "Found {1} objects" + vbLf, endtime - starttime, dataTable.Rows.Count)
            Catch ex As System.Exception
                MsgBox(vbCr & ex.ToString & vbCr & ex.StackTrace)
            End Try
            '' Display the  file
            Process.Start("lines.xml", Nothing)
        End Sub
        Public Function extractLines(ByVal fname As String) As System.Data.DataTable
            Dim dataTable As New System.Data.DataTable()
            Dim blkTable As New System.Data.DataTable()
            Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim ed As Editor = doc.Editor
            Dim tags As New List(Of String)()
            If Not System.IO.File.Exists(fname) Then
                ed.WriteMessage(vbLf & "Drawing file does not exist.")
                Return Nothing
                Exit Function
            End If
            Dim es As IDxExtractionSettings = New DxExtractionSettings()
            Dim de As IDxDrawingDataExtractor = es.DrawingDataExtractor
            de.Settings.ExtractFlags = ExtractFlags.None Or ExtractFlags.ModelSpaceOnly
            de.Settings.ExtractFlags = ExtractFlags.ExtractBlockOnly ''Or ExtractFlags.ModelSpaceOnly
            Dim fr As IDxFileReference = New DxFileReference(Path.GetDirectoryName(fname), fname)
            de.Settings.DrawingList.AddFile(fr)
            ' Scan the drawing for object types & their properties
            de.DiscoverTypesAndProperties(Path.GetDirectoryName(fname))
            Dim types As List(Of IDxTypeDescriptor) = de.DiscoveredTypesAndProperties
            ' Select all the types and properties for extraction
            ' by adding them one-by-one to these two lists
            Dim selTypes As New List(Of String)()
            Dim selProps As New List(Of String)()
            For Each type As IDxTypeDescriptor In types
                selTypes.Add(type.GlobalName)
                For Each pr As IDxPropertyDescriptor In type.Properties
                    If Not selProps.Contains(pr.GlobalName) Then
                        selProps.Add(pr.GlobalName)
                    End If
                Next
            Next
            de.Settings.SetSelectedTypesAndProperties(types, selTypes, selProps)
            ' Now perform the extraction itself
            de.ExtractData(Path.GetDirectoryName(fname))
            ' Get the results of the extraction
            dataTable = de.ExtractedData
            If dataTable.Rows.Count > 0 Then
                dataTable.TableName = "Lines"
                Dim selrows As DataRow() = dataTable.Select("AcDxObjectTypeGlobalName Like '%Line' Or AcDxObjectTypeGlobalName Like '%Text' Or AcDxObjectTypeGlobalName Like '%MText'")
                blkTable = dataTable.Clone()
                For Each dr As DataRow In selrows
                    blkTable.ImportRow(dr)
                Next
                '' commented lines is just for populating form listbox control
                'Dim columns As String() = New String() {"AcDxObjectTypeName"}
                'Dim dvw As DataView = blkTable.DefaultView
                'distinctTable = dvw.ToTable(False, columns)
                'Dim bnames As New List(Of String)()
                'For Each dr As System.Data.DataRow In distinctTable.Rows
                '    Dim bname As String = dr(0).ToString()
                '    If Not bnames.Contains(bname) Then
                '        bnames.Add(bname)
                '    End If
                'Next
                'Me.lst.DataSource = bnames'' <-- to fill ListBox only
                'lst.SelectedIndex = -1'' <-- set selected items to nothing
            End If
            Return blkTable
        End Function
GMT+8, 2026-11-3 03:09 , Processed in 0.405112 second(s), 28 queries , Gzip On.
