查看: 1922|回复: 2
[分享] Import SymbolTableRecords
已领礼包: 859个
发表于 2014-6-7 03:31:11 | 显示全部楼层 |阅读模式
A generic extension method to import SymbolTableRecord objects from a dwg (or dwt) file into a Database.
The ImportSymbolTableRecords() method extends the Database type, that's to say it can be called with the dot(.) operator from a Database instance.
It is generic because it can target any SymbolTable using a Type parameter.
The requiered arguments are the source file full path and ParamArray of strings (one or more SymbolTableRecord names).
The function returns an ObjectIdCollection containing the ObjectId of the cloned SymbolTableRecords (null/Nothing if none have been imported).
C#
Extension methods have to be defined within a static class, they have to be static and their first argument must use the 'this' keyword and be the same type as the extended one.
    public static class Extension
        public static ObjectIdCollection ImportSymbolTableRecords<T>(
            this Database targetDb,
            string sourceFile,
            params string[] recordNames)
            where T : SymbolTable
            using (Database sourceDb = new Database())
                sourceDb.ReadDwgFile(sourceFile, System.IO.FileShare.Read, false, "");
                ObjectId sourceTableId, targetTableId;
                switch (typeof(T).Name)
                    case "BlockTable":
                        sourceTableId = sourceDb.BlockTableId;
                        targetTableId = targetDb.BlockTableId;
                        break;
                    case "DimStyleTable":
                        sourceTableId = sourceDb.DimStyleTableId;
                        targetTableId = targetDb.DimStyleTableId;
                        break;
                    case "LayerTable":
                        sourceTableId = sourceDb.LayerTableId;
                        targetTableId = targetDb.LayerTableId;
                        break;
                    case "LinetypeTable":
                        sourceTableId = sourceDb.LinetypeTableId;
                        targetTableId = targetDb.LinetypeTableId;
                        break;
                    case "RegAppTable":
                        sourceTableId = sourceDb.RegAppTableId;
                        targetTableId = targetDb.RegAppTableId;
                        break;
                    case "TextStyleTable":
                        sourceTableId = sourceDb.TextStyleTableId;
                        targetTableId = targetDb.TextStyleTableId;
                        break;
                    case "UcsTable":
                        sourceTableId = sourceDb.UcsTableId;
                        targetTableId = targetDb.UcsTableId;
                        break;
                    case "ViewTable":
                        sourceTableId = sourceDb.ViewportTableId;
                        targetTableId = targetDb.ViewportTableId;
                        break;
                    case "ViewportTable":
                        break;
                    default:
                        throw new ArgumentException("Requires a concrete type derived from SymbolTable");
                using (Transaction tr = sourceDb.TransactionManager.StartTransaction())
                    T sourceTable = (T)tr.GetObject(sourceTableId, OpenMode.ForRead);
                    ObjectIdCollection idCol = new ObjectIdCollection();
                    foreach (string name in recordNames)
                        if (sourceTable.Has(name))
                            idCol.Add(sourceTable[name]);
                    if (idCol.Count == 0)
                        return null;
                    IdMapping idMap = new IdMapping();
                    sourceDb.WblockCloneObjects(
                        idCol, targetTableId, idMap, DuplicateRecordCloning.Replace, false);
                    tr.Commit();
                    ObjectIdCollection retVal = new ObjectIdCollection();
                    foreach (ObjectId id in idCol)
                        if (idMap[id].IsCloned)
                            retVal.Add(idMap[id].Value);
                    return retVal.Count == 0 ? null : retVal;
已领礼包: 859个
 楼主| 发表于 2014-6-7 03:32:02 | 显示全部楼层
using example
ObjectIdCollection result =
    db.ImportSymbolTableRecords<TextStyleTable>(@"F:\gile\Templates\Standard2010.dwt", "Arial_Std", "Romans_Std");
发表于 2018-8-24 01:38:14 | 显示全部楼层
解决了困扰我的一个文件,我以前是将带有SymbolTableRecord的Entity复制到目标数据库中来获取SymbolTableRecord,这个扩展方法解决了我的问题。
GMT+8, 2026-11-3 00:54 , Processed in 0.464643 second(s), 32 queries , Gzip On.
