查看: 1546|回复: 0
[分享] Create new layer by selecting a single object
已领礼包: 859个
发表于 2014-6-7 03:35:05 | 显示全部楼层 |阅读模式
       [CommandMethod("CopyLayerFromObject")]
        public void testCopyLayer()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            PromptStringOptions sopts = new PromptStringOptions("\nEnter new layer name :");
            sopts.AllowSpaces = true;
            PromptResult stres = ed.GetString(sopts);
            if (stres.Status != PromptStatus.OK) return;
            // get new layer name
            string layerName = stres.StringResult;
            PromptSelectionOptions opts = new PromptSelectionOptions();
            opts.MessageForRemoval = "Wrong selection, try again.";
            opts.MessageForAdding = "Select single object to copy layer from: ";
            opts.SingleOnly = true;
            opts.SinglePickInSpace = true;
            // select single object
            PromptSelectionResult selRes = ed.GetSelection(opts);
            if (selRes.Status != PromptStatus.OK) return;
            ObjectId entId = selRes.Value.GetObjectIds()[0];
            // open transaction
            using (Transaction tr = db.TransactionManager.StartTransaction())
                LayerTable ltb = (LayerTable)tr.GetObject(db.LayerTableId, OpenMode.ForRead);
                // get entity
                Entity ent = (Entity)tr.GetObject(entId, OpenMode.ForRead);
                // get entity layer
                string oldname = ent.Layer;
                // get LayerTableRecord by name
                LayerTableRecord oldLtr = (LayerTableRecord)tr.GetObject(ltb[oldname], OpenMode.ForRead);
                // check if layer exists
                if (!ltb.Has(layerName))
                    ltb.UpgradeOpen();
                    //create new layer
                    LayerTableRecord ltr = new LayerTableRecord();
                    // copy properties from entity layer
                    ltr.CopyFrom(oldLtr);
                    // add new layer name
                    ltr.Name = layerName;
                    // here you can to add other properties to a layer: linetype, color etc
                    // add layer to LayerTable
                    ltb.Add(ltr);
                    // confirm transaction
                    tr.AddNewlyCreatedDBObject(ltr, true);
                // end command if layer exist
                else
                    return;
                tr.Commit();
            }//end using transaction
GMT+8, 2026-11-3 02:32 , Processed in 0.453885 second(s), 28 queries , Gzip On.
