查看: 1402|回复: 1
[分享] Two programs to set layers off or isolates layers by picking an entity on sc...
已领礼包: 859个
发表于 2014-6-7 03:36:02 | 显示全部楼层 |阅读模式
         [CommandMethod("liso")]
        public static void testLayerIsol()
            Database db = HostApplicationServices.WorkingDatabase;
            Editor ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor;
            PromptEntityOptions opt = new PromptEntityOptions( "\nSelect an entity :");
                PromptEntityResult res = ed.GetEntity(opt);
                if (res.Status != PromptStatus.OK) return;
                    ObjectId entId=  res.ObjectId;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                Entity ent= tr.GetObject(entId, OpenMode.ForRead) as Entity;
                if (ent==null) return;
                string lname= ent.Layer;
                using (LayerTable lt = db.LayerTableId.GetObject(OpenMode.ForRead, false) as LayerTable)
                    db.Clayer=lt[lname];
                    foreach (ObjectId layId in lt)
                        if (layId != lt[lname])
                            LayerTableRecord ltr = tr.GetObject(layId, OpenMode.ForWrite, false) as LayerTableRecord;
                            if ((!ltr.IsDependent) && ((!ltr.Name.Contains("*|*")) | (!ltr.Name.Contains("X*"))))
                                ltr.IsOff = true;
                tr.Commit();
已领礼包: 859个
 楼主| 发表于 2014-6-7 03:36:45 | 显示全部楼层
        [CommandMethod("loff")]
        public static void testLayersOff()
                   LayerTableRecord clayer = tr.GetObject(db.Clayer, OpenMode.ForRead) as LayerTableRecord;  //current layer
                    if (lt[lname]==db.Clayer)
                        Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog("Could not turn off the current layer.");
                        return;
                    LayerTableRecord ltr = tr.GetObject(lt[lname], OpenMode.ForWrite, false) as LayerTableRecord;
                        ltr.IsOff = true;
                tr.Commit();
GMT+8, 2026-11-3 06:26 , Processed in 0.422876 second(s), 30 queries , Gzip On.
