查看: 1678|回复: 1
[分享] Work on locked layers sample
已领礼包: 859个
发表于 2014-6-7 03:37:27 | 显示全部楼层 |阅读模式
       [CommandMethod("WorkWithLockedLayers","wlock", CommandFlags.UsePickSet | CommandFlags.Redraw)]
        public void testWorkOnLockedLayers()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            bool fine = true;
            ObjectIdCollection locked = new ObjectIdCollection();
            try
                using (Transaction tr = db.TransactionManager.StartTransaction())
                    LayerTable lt = (LayerTable)tr.GetObject(db.LayerTableId, OpenMode.ForRead);
                    foreach (ObjectId ltId in lt)
                        if (ltId.IsValid && ltId.IsResident && !ltId.IsErased) // just drawing layers were allowed
                            LayerTableRecord ltr = (LayerTableRecord)tr.GetObject(ltId, OpenMode.ForRead);
                            if (ltr.IsLocked)
                                locked.Add(ltId);
                                ltr.UpgradeOpen();
                                ltr.IsLocked = false;
                                ltr.DowngradeOpen();// optional
                    // Here you begin to work with objects and not worry that they are in the locked layers
                    // e.g. itrerate through selection etc. (poor code commented)
                    //SelectionSet ss = ed.SelectAll().Value;
                    //foreach (ObjectId id in ss.GetObjectIds())
                    //    Entity ent = (Entity)tr.GetObject(id, OpenMode.ForWrite);
                    //    ent.ColorIndex = 121;
                        LayerTableRecord ltr = (LayerTableRecord)tr.GetObject(ltId, OpenMode.ForWrite);
                        ltr.IsLocked = true;
                    tr.Commit();
            catch (Autodesk.AutoCAD.Runtime.Exception ex)
                fine = false;
                ed.WriteMessage(ex.ToString());
            finally
                if (!fine)
                    doc.SendStringToExecute("_layerp", true, false, false);
发表于 2014-6-7 09:58:19 | 显示全部楼层
333333333333333333:loveliness:
GMT+8, 2026-11-3 01:53 , Processed in 0.467853 second(s), 30 queries , Gzip On.
