查看: 1589|回复: 0
[分享] Get the layout an entity belongs to
已领礼包: 859个
发表于 2014-6-7 03:40:51 | 显示全部楼层 |阅读模式
  // based on code from:
  // http://adndevblog.typepad.com/au ... ity-belongs-to.html
  [CommandMethod("EntityLayoutName","enl", CommandFlags.Modal)]
        static public void GetEntityLayout()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database db = doc.Database;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                PromptEntityOptions peo = new PromptEntityOptions("\nSelect object >>");
                PromptEntityResult res;
                res = ed.GetEntity(peo);
                if (res.Status != PromptStatus.OK)
                    return;
                Entity ent = (Entity)tr.GetObject(res.ObjectId, OpenMode.ForRead);
                if (ent == null)
                    return;
                BlockTableRecord btr = tr.GetObject(ent.OwnerId, OpenMode.ForRead, true) as BlockTableRecord;
                Layout lt = tr.GetObject(btr.LayoutId, OpenMode.ForRead, true) as Layout;
                string layoutName = lt.LayoutName;
                ed.WriteMessage("\nThe layout the selected entity belongs to is {0}", layoutName);
GMT+8, 2026-11-3 06:30 , Processed in 0.524286 second(s), 28 queries , Gzip On.
