查看: 1949|回复: 0
[分享] offset polyline
已领礼包: 859个
发表于 2014-6-7 03:45:28 | 显示全部楼层 |阅读模式
        // Replace "accore.dll" by "acad.exe" for AutoCAD versions prior to 2013
        [System.Security.SuppressUnmanagedCodeSecurity]
        [DllImport("acad.exe", EntryPoint = "acedCmd", CharSet = CharSet.Unicode, CallingConvention = CallingConvention.Cdecl)]
        extern static private int acedCmd(IntPtr resbuf);
        [CommandMethod("offpl")]
        public void cmdOffset()
            ResultBuffer rb = new ResultBuffer();
            // RTSTR = 5005
            rb.Add(new TypedValue(5005, "_.OFFSET"));
            // start the insert command
            acedCmd(rb.UnmanagedObject);
            bool quit = false;
            // loop round while the insert command is active
            while (!quit)
                // see what commands are active
                string cmdNames = (string)Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("CMDNAMES");
                // if the INSERT command is active
                if (cmdNames.ToUpper().IndexOf("OFFSET") >= 0)
                    // then send a PAUSE to the command line
                    // RTSTR = 5005 - send a user pause to the command line
                    rb.Add(new TypedValue(5005, "\\"));
                else
                    // otherwise quit
                    quit = true;
GMT+8, 2026-11-3 03:09 , Processed in 0.291319 second(s), 28 queries , Gzip On.
