查看: 1686|回复: 0
[分享] GetActiveViewportExtents
已领礼包: 859个
发表于 2014-6-7 17:37:29 | 显示全部楼层 |阅读模式
// Copyright (C) 2011 by EDA Inc.
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
// Project references to both AcMgd.dll & AcDbMgd.dll of ObjectARX are required.
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.EditorInput;
namespace EDAInc.AcadAPI
    internal static class AcadHelper
        // Generates the transformation matrix to go from WCS to DCS
        // units in a view/viewport.
        //      WCS - World Coordinate System
        //      DCS - Display Coordinate System
        // Copied from:
        //      http://through-the-interface.typ ... _interface/2011/11/
        //                         navigating-an-autocad-model-using-kinect-part-1.html
        // To get a DCS to WCS transformation matrix, use the inverse of
        // the return matrix.  E.g.,
        //      Matrix3d dcs2wcs = Wcs2Dcs(vtr).Inverse();
        public static Matrix3d Wcs2Dcs(AbstractViewTableRecord vtr)
            Matrix3d mat = Matrix3d.PlaneToWorld(vtr.ViewDirection);
            mat = Matrix3d.Displacement(vtr.Target - Point3d.Origin) * mat;
            mat = Matrix3d.Rotation(
                    -vtr.ViewTwist, vtr.ViewDirection, vtr.Target) * mat;
            return mat.Inverse();
        public static bool GetActiveViewportExtents(Document aDoc,
                                                    out Point3d aMinExtWCS,
                                                    out Point3d aMaxExtWCS)
            if (aDoc == null)
                aDoc = Application.DocumentManager.MdiActiveDocument;
            Database db = aDoc.Database;
            Editor ed = aDoc.Editor;
            using (Transaction tr = db.TransactionManager.StartTransaction()) {
                try {
                    ed.UpdateTiledViewportsInDatabase();
                    // Open the active view port.
                    ViewportTableRecord vp_rec = (ViewportTableRecord)
                            tr.GetObject(ed.ActiveViewportId, OpenMode.ForRead);
                    // Find the min & max extents of the active view port in the DCS.
                    Point2d center_dcs = vp_rec.CenterPoint;
                    double half_width_dcs = vp_rec.Width / 2;
                    double half_height_dcs = vp_rec.Height / 2;
                    Point3d min_ext_dcs = new Point3d(
                            center_dcs.X - half_width_dcs,
                            center_dcs.Y - half_height_dcs,
                            0);
                    Point3d max_ext_dcs = new Point3d(
                            center_dcs.X + half_width_dcs,
                            center_dcs.Y + half_height_dcs,
                            0);
                    // Convert the min & max extents of the view port to WCS.
                    Matrix3d dcs2wcs = AcadHelper.Wcs2Dcs(vp_rec).Inverse();
                    aMinExtWCS = min_ext_dcs.TransformBy(dcs2wcs);
                    aMaxExtWCS = max_ext_dcs.TransformBy(dcs2wcs);
                    tr.Commit();
                    return true;
                catch (Autodesk.AutoCAD.Runtime.Exception ex) {
                    tr.Abort();
                    ed.WriteMessage("\n" + ex.Message + "\n");
                    aMinExtWCS = Point3d.Origin;
                    aMaxExtWCS = Point3d.Origin;
                    return false;
GMT+8, 2026-11-3 03:11 , Processed in 0.419420 second(s), 28 queries , Gzip On.
