查看: 1923|回复: 1
[分享] Positioning a selected entity at view center
已领礼包: 859个
发表于 2014-6-9 00:48:50 | 显示全部楼层 |阅读模式
Positioning a selected entity at view center                         By Balaji Ramamoorthy
Here is a code snippet to position an entity at the center of the view. Most of this code is similar to the way we would zoom on to an entity except that the Width and Height of the view is not modified. In this case, it is only relevant to set the view center point in DCS.
Document doc = Application.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
Editor ed = doc.Editor;
PromptEntityOptions peo
            = new PromptEntityOptions("\nSelect an entity:");
PromptEntityResult per = ed.GetEntity(peo);
if (per.Status != PromptStatus.OK)
    return;
ed.UpdateTiledViewportsInDatabase();
using (Transaction tr = db.TransactionManager.StartTransaction())
    Entity ent = tr.GetObject(
                    per.ObjectId, OpenMode.ForRead) as Entity;
    Extents3d entityExtent = ent.GeometricExtents;
    ViewportTable vpTbl = tr.GetObject(
                                        db.ViewportTableId,
                                        OpenMode.ForRead
                                      ) as ViewportTable;
    ViewportTableRecord viewportTableRec
           = tr.GetObject(vpTbl["*Active"], OpenMode.ForWrite)
                                       as ViewportTableRecord;
    Matrix3d matWCS2DCS
       = Matrix3d.PlaneToWorld(viewportTableRec.ViewDirection);
    matWCS2DCS = Matrix3d.Displacement(
        viewportTableRec.Target - Point3d.Origin) * matWCS2DCS;
    matWCS2DCS = Matrix3d.Rotation
                                 -viewportTableRec.ViewTwist,
                                 viewportTableRec.ViewDirection,
                                 ) * matWCS2DCS;
    matWCS2DCS = matWCS2DCS.Inverse();
    entityExtent.TransformBy(matWCS2DCS);
    Point2d center = new Point2d(
    (entityExtent.MaxPoint.X + entityExtent.MinPoint.X) * 0.5,
    (entityExtent.MaxPoint.Y + entityExtent.MinPoint.Y) * 0.5);
    viewportTableRec.CenterPoint = center;
    tr.Commit();
发表于 2018-8-23 22:53:49 | 显示全部楼层
试了,在AutoCAD2010中,没看出任何效果,
GMT+8, 2026-11-3 00:13 , Processed in 0.405918 second(s), 30 queries , Gzip On.
