查看: 1526|回复: 0
[分享] SystemVariableEnumerator – new class in AutoCAD 2015
已领礼包: 859个
发表于 2014-6-9 00:52:27 | 显示全部楼层 |阅读模式
SystemVariableEnumerator – new class in AutoCAD 2015                         By Virupaksha Aithal
SystemVariableEnumerator class provides a way to iterate over all of the public system variables and get their names, data type, range (if applicable), read-only status, and how they are stored. In ObjectARX this call is represented by “AcEdSysVarIterator”
[CommandMethod("SysVarListTest")]
public void SysVarListTest() // This method can have any name
    Document doc = Application.DocumentManager.MdiActiveDocument;
    Editor ed = doc.Editor;
    using(SystemVariableEnumerator sysVar
                        = new SystemVariableEnumerator())
        string storage = "";
        while (sysVar.MoveNext())
            Variable var = sysVar.Current;
            switch (var.Storage)
                case Variable.StorageType.PerDatabase:
                    storage = "PerDatabase";
                    break;
                case Variable.StorageType.PerProfile:
                    storage = "PerProfile";
                    break;
                case Variable.StorageType.PerSession:
                    storage = "PerSession";
                    break;
                case Variable.StorageType.PerUser:
                    storage = "PerUser";
                    break;
                case Variable.StorageType.PerViewport:
                    storage = "PerViewport";
                    break;
            ed.WriteMessage(var.Name + "   " + storage + "\n");
    //use Application.GetSystemVariable() to get the value.
GMT+8, 2026-11-3 06:17 , Processed in 0.510352 second(s), 28 queries , Gzip On.
