查看: 1744|回复: 0
[分享] How to exit “Editor.GetSelection” on keyword selection
已领礼包: 859个
发表于 2014-6-9 01:04:39 | 显示全部楼层 |阅读模式
How to exit “Editor.GetSelection” on keyword selection                         By Virupaksha Aithal
One way to exit the “GetSelection” API on keyword selection is to throw an AutoCAD exception from the keyword press event handler. Below is a sample example of the procedure. On press of any keyword, below code throws the “Autodesk.AutoCAD.Runtime.ErrorStatus.OK” exception passing the keyword pressed. This exception is handled in the code to identify the keyword pressed.
[CommandMethod("SELKW")]
publicvoid GetSelectionWithKeywords()
    Document doc =
        Application.DocumentManager.MdiActiveDocument;
    Editor ed = doc.Editor;
    // Create our options object
    PromptSelectionOptions pso = newPromptSelectionOptions();
    // Add our keywords
    pso.Keywords.Add("FIrst");
    pso.Keywords.Add("Second");
    // Set our prompts to include our keywords
    string kws = pso.Keywords.GetDisplayString(true);
    pso.MessageForAdding =
                "\nAdd objects to selection or " + kws;
    pso.MessageForRemoval =
            "\nRemove objects from selection or " + kws;
    pso.KeywordInput +=
           newSelectionTextInputEventHandler(pso_KeywordInput);
    PromptSelectionResult psr = null;
    try
        psr = ed.GetSelection(pso);
        if (psr.Status == PromptStatus.OK)
            //your logic
    catch (System.Exception ex)
        if (ex is Autodesk.AutoCAD.Runtime.Exception)
            Autodesk.AutoCAD.Runtime.Exception aEs =
                    ex as Autodesk.AutoCAD.Runtime.Exception;
            //user has pressed keyword.
            if (aEs.ErrorStatus ==
                        Autodesk.AutoCAD.Runtime.ErrorStatus.OK)
                ed.WriteMessage("\nKeyword entered: {0}",
                                                     ex.Message);
            else
                //other exception, please handle
void pso_KeywordInput(object sender, SelectionTextInputEventArgs e)
    //user has pressed keyword, so throw Exception
    throw new Autodesk.AutoCAD.Runtime.Exception(
                Autodesk.AutoCAD.Runtime.ErrorStatus.OK, e.Input);
GMT+8, 2026-11-3 01:50 , Processed in 0.586499 second(s), 28 queries , Gzip On.
