查看: 1676|回复: 0
[分享] 在autocad.net中加载lisp程序的方法 - swtool
已领礼包: 859个
发表于 2014-6-9 01:14:45 | 显示全部楼层 |阅读模式
using Autodesk.AutoCAD.Windows;
using Autodesk.AutoCAD.Runtime;
using System.Windows.Forms;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.ApplicationServices;
using System;
using System.Collections;
using app = Autodesk.AutoCAD.ApplicationServices.Application;
namespace test{
    [CommandMethod("test"
    public void test()
    {      //设置标记并发送PLINE
      Document curAcadDoc = app.DocumentManager.MdiActiveDocument;
      string lispPath = "d:/1.lsp";
            string loadStr = String.Format("(load \"{0}\")  tttt\n", lispPath);
      curAcadDoc.SendStringToExecute(loadStr, false, false, false);
http://www.tuicool.com/articles/jiy26f
GMT+8, 2026-11-3 10:43 , Processed in 0.478662 second(s), 27 queries , Gzip On.
