查看: 1791|回复: 0
[分享] Import blocks from an external DWG file using .NET
已领礼包: 859个
发表于 2014-6-9 02:47:38 | 显示全部楼层 |阅读模式
http://through-the-interface.typepad.com/through_the_interface/2006/08/import_blocks_f.html
We're going to use a "side database" - a drawing that is loaded in memory, but not into the AutoCAD editor - to import the blocks from another drawing into the one active in the editor.
Here's some C# code. The inline comments describe what is being done along the way. Incidentally, the code could very easily be converted into a RealDWG application that works outside of AutoCAD (we would simply need to change the destDb from the MdiActiveDocument's Database to the HostApplicationServices' WorkingDatabase, and use a different user interface for getting/presenting strings from/to the user).
using System;
using Autodesk.AutoCAD;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using System.Collections.Generic;
namespace BlockImport
  public class BlockImportClass
    [CommandMethod("IB")]
    public void ImportBlocks()
      DocumentCollection dm =
          Application.DocumentManager;
      Editor ed = dm.MdiActiveDocument.Editor;
      Database destDb = dm.MdiActiveDocument.Database;
      Database sourceDb = new Database(false, true);
      PromptResult sourceFileName;
      try
        // Get name of DWG from which to copy blocks
        sourceFileName =
          ed.GetString("\nEnter the name of the source drawing: ");
        // Read the DWG into a side database
        sourceDb.ReadDwgFile(sourceFileName.StringResult,
                            System.IO.FileShare.Read,
                            true,
        // Create a variable to store the list of block identifiers
        ObjectIdCollection blockIds = new ObjectIdCollection();
        Autodesk.AutoCAD.DatabaseServices.TransactionManager tm =
          sourceDb.TransactionManager;
        using (Transaction myT = tm.StartTransaction())
          // Open the block table
          BlockTable bt =
              (BlockTable)tm.GetObject(sourceDb.BlockTableId,
                                      OpenMode.ForRead,
                                      false);
          // Check each block in the block table
          foreach (ObjectId btrId in bt)
            BlockTableRecord btr =
              (BlockTableRecord)tm.GetObject(btrId,
                                            OpenMode.ForRead,
                                            false);
            // Only add named & non-layout blocks to the copy list
            if (!btr.IsAnonymous && !btr.IsLayout)
              blockIds.Add(btrId);
            btr.Dispose();
        // Copy blocks from source to destination database
        IdMapping mapping = new IdMapping();
        sourceDb.WblockCloneObjects(blockIds,
                                    destDb.BlockTableId,
                                    mapping,
                                    DuplicateRecordCloning.Replace,
                                    false);
        ed.WriteMessage("\nCopied "
                        + blockIds.Count.ToString()
                        + " block definitions from "
                        + sourceFileName.StringResult
                        + " to the current drawing.");
      catch(Autodesk.AutoCAD.Runtime.Exception ex)
          ed.WriteMessage("\nError during copy: " + ex.Message);
      sourceDb.Dispose();
GMT+8, 2026-11-3 10:47 , Processed in 0.489055 second(s), 28 queries , Gzip On.
